    changing the auto bed leveling locations
    Firmware installation
    • nodashiundefined
      nodashi
      Im sorry if this has been asked already but, Im looking to change the locations of auto bed leveling. Not the bed mesh grid but just the 4 points it probes before you can do mesh grid leveling. The carriage hits the end of the extrusion when leveling the right side because the bltouch is so far to the left. I've been able to compensate for it in the mesh grid leveling, but i have no idea how you do it on the g29 command. thanks
        Are you using the facility to have the firmware level the bed by adjusting the Z leadscrew motors individually? If so, then the locations of the probe points are in the G30 commands in the bed.g file. If you are not using that facility, then you need only run mesh bed probing.
