    Urgent: Help needed for Duet 3D Delta Printer working
    Firmware installation
    • YD14undefined
      YD14
      Proper homing is not happening for my Delta printer. Kindly guide for the same:
      My Code: Config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Tue Dec 04 2018 11:34:12 GMT+0530 (India Standard Time)
      G21 ; All units in millimeters
      M665 R105.6 L340 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M550 P"My Printer" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M92 X100.00 Y100.00 Z100.00 E663.00 ; Set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
      M906 X1000.00 Y1000.00 Z1000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
      M557 R85 S20 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      Home.g
      ; homedelta.g
      G91 ; relative positioning
      G1 S1 X500 Y500 Z500 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
      G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
      G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; move X+Y to the centre
        dc42 administrators @YD14
        @yd14 said in Urgent: Help needed for Duet 3D Delta Printer working:
        Please explain what is going wrong. Here are some wiki references that you may find helpful:
        https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually
        https://duet3d.dozuki.com/Wiki/FAQ#Section_When_I_try_to_home_my_printer_sometimes_the_carriage_or_carriages_move_only_part_of_the_way_towards_the_homing_switches_and_I_have_to_command_it_to_home_again_to_make_it_go_all_the_way
        PlasticMetalundefined 1 Reply Last reply Reply Quote 1
        • PlasticMetalundefined
          PlasticMetal @dc42
          @dc42 Thanks David! I had overlooked setting the max potential homing distance when I built my new delta (largely based on your Kossel), and couldn't figure out why it would sometimes take 2 attempts to home.
          I had used the RR configurator, and so I believe it chose the G1 values in homedelta.g, just plugging in my max Z (~460mm). In reality, the max distance any carriage may have to travel was closer to 580mm, when an arm is stretched way out to near the edge of the bed.
          • YD14undefined
            YD14
            @dc42 Hello David.
            When I take test for motors through macros, they work fine. But when I try to home all the axes for my Delta printer, they just move 5 mm up and stop. I am hereby attaching video for home movement. The upward movement in the video is not that visible.
            Furthermore, when I try to move X , Y and Z axes through steps, X and Y move really well as in upward for positive steps and downwards for negative steps (1, 10 mm etc.). But that is not the case with Z axis. For positive steps Z moves downwards and for negative it goes upwards. I tried to change the polarity for Z-axis (through software and hardware), but there is not any success.
            Kindly guide me to resolve the issue.
            [0_1546517715814_home.mp4](Uploading 100%)
              @yd14, to change the direction of the Z motor, find the M569 P2 command in config.g and change S0 to S1 or vice versa.
              The other problem is likely to be caused by incorrect endstop switch configuration. Test the endstop switches as described at https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches.
