    Bug in Duet 0.8.5 firmware 1.23 with G10: Retract
    Firmware installation
    1.3k
    • PDBealundefined
      PDBeal
      I've been experimenting with my E3D Cyclops and my Dual Direct Drive Titan design and things are working rather well. However, due to the Cyclops setup I've had to switch to firmware retraction. I've managed to make Cura 3.6 use Firmware Retraction and it enters G10 and G11 appropriately, except when it does a Tool switch it inserts a "G10 S1" . This G10 S1 command is setting the temperature of my heater to 1.
      Reading the G-code pages at the RepRap Wiki for G10, It says G10 S1 is for repetier only but signifies a long retract and a short retract. However, there is a note "RepRapFirmware recognizes G10 as a command to set tool offsets and/or temperatures if the P parameter is present, and as a retraction command if it is absent." Since the G10 S1 has no P parameter I figured it would be ok, but apparently that checking for a P parameter doesn't work.
      For the short term, I'm just search and replace G10 S1 to G10, but based on the Wiki, it shouldn't be setting temperature to 1 without the P parameter? I suspect this is an issue in the 2.x firmware although I have no way of checking as I only have 0.8.5 boards.
      I've attached my G-Code for the simple traffic code that has this G10 S1. I've not yet refined my start code and some lines are repetitive, but it works apart from the G10 S1.
      0_1546909708932_CFFFP_Traffic_Cone_Rings_Dual_Bad.gcode
        Here's the RepRapFirmware gcode wiki for reference. Use this one instead.
        https://duet3d.dozuki.com/Wiki/GCode#Section_G10_Tool_Offset
        You may still be right about the P parameter though.
          The behaviour of G10 was changed several firmware versions ago because a user needed to be able to use G10 to set the temperatures for the current tool without knowing the tool number. So now G10 with a P or S or R parameter sets temperatures and/or offsets, and G10 with none of those parameters is a retraction command.
          I've not heard before of S1 being used to choose between 2 different retraction lengths. I think it must be a recent addition.
          Are you sure that the G10 S1 command isn't in a tool change script that can be edited?
          • PDBealundefined
            PDBeal
            I don't have any tool change things defined in Cura. I had to stop Cura from trying to control the heaters too as it's dual extrusion expects two heaters from what I've seen. In my case, I don't even have anything in tfree0, tpre0, tpost0 either because I don't need it. And I just adjust my start code for my desired temperatures.
            From what I suspect, based on the RepRap Wiki for G10 S1, Repetier has something implemented for a long retract probably to support one of those promethius setups with 1 hotend and 2 filaments with the filament switch happening above the cold zone of the hotend. I'm also guessing Cura has implemented this G10 S1 for those types of cases also with it only using G10 S1 on Tool change locations.
              dc42 administrators @PDBeal
              Perhaps @burtgoogle can change Cura so that it doesn't generate the S parameter when the GCode flavour is RepRapFirmware?
              burtoogleundefined 1 Reply Last reply Reply Quote 0
              • burtoogleundefined
                burtoogle @dc42
                @dc42 said in Bug in Duet 0.8.5 firmware 1.23 with G10: Retract:
                My ears are burning.
                Looking at the Cura code, it currently does this:
                        *output_stream << "G10";
                        if (extruder_switch)
                            *output_stream << " S1";
                And what you want is more like this: ?
                        if (extruder_switch && flavor != EGCodeFlavor::REPRAP)
                I understand why you want to remove the S1 but, surely, it's not ideal to have G10 so overloaded. How did that happen?
                  burtoogle
                  BTW, the Cura developers have pretty much stopped processing PRs on the Cura slicer. I have quite a backlog of PRs that they are simply ignoring. It's not personal (I think) because they don't appear to be processing any PRs unless they provide some kind of sexy feature (like gyroid infill) which they grabbed with (relatively) indecent haste.
                    burtoogle
                    See https://github.com/Ultimaker/CuraEngine/pull/972
                    I will incorporate this into my next Cura release which you can find at https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
                    smartavionics opened this pull request in Ultimaker/CuraEngine
                    closed Bug Fix - Only add S1 param to G10 when generating repetier flavour gcode. #972
                      dc42 administrators @burtoogle
                      @burtoogle said in Bug in Duet 0.8.5 firmware 1.23 with G10: Retract:
                      I think it started when someone developing some 3D printer firmware (Marlin?) appropriated G10 for firmware retraction, ignoring the fact that G10 had been used for many years by the CNC community for coordinate setting functions (it's in the NIST GCode standard). It didn't help that the early developers of RepRapFirmware independently added temperature-setting functions to G10, although that didn't clash with NIST.
                      I have been considering moving the temperature-setting functions (and possibly also the tool offset functions) away from G10 to a completely new M-code, perhaps maintaining a backwards-compatibility option for several firmware versions to give users a chance to update DWC and PanelDueFirmware. The M104/M109 temperature setting functions are not flexible enough to fully handle RepRapFirmware's versatile tool and heater management, but perhaps M104 could be extended.
                        burtoogle
                        Understood, thanks @dc42.
                        • PDBealundefined
                          PDBeal
                          Apparently, in Cura 4.0.0, for RepRapFirmware, it still generated G10 S1.
                          • PDBealundefined
                            PDBeal
                            Submitted Bug Report to Cura.
                            https://github.com/Ultimaker/Cura/issues/5881
                            PDBeal created this issue in Ultimaker/Cura
                            closed [3.6-4.0] G10: Retract Issue with RepRap machine selection #5881
                              burtoogle
                              See https://github.com/Ultimaker/CuraEngine/commit/00bc58391afd6b94b4112d3492d5bd8adba013a5
                              0 smartavionics committed to Ultimaker/CuraEngine
                              The other firmwares can interpret the S1 differently so don't let them see it.
