    Software to use 3D printer as an engraver (spindle motor)?
    CNC
    • SplatHammerundefined
      SplatHammer
      I have a large heavy duty 3D printer with a Duet wifi controller. I want to use it to engrave text into aluminium. I have a 480 watt motor which I am going to attach to the frame and then attach a flexible shaft between it and where the hot end is now. The text is going to be fairly small and I have some 0.4mm cutting/engraving bits.
      What software do I need to convert text into GCode to send to the printer? I have searched but everything seems to be aimed at laser engraving.
        You can use Fusion 360 to achieve the pathing needed.
          SplatHammer
          So I guess you mean the following:
          Create the text, generate the gcode and then manually put in the z axis commands to raise and lower the cutter?
            Phaedrux Moderator @SplatHammer
            @splathammer I mean using fusion for CAM.
            https://blog.adafruit.com/2017/09/01/new-tutorial-using-cam-in-fusion-360-for-engraving/
            https://youtu.be/xoji-oqLSCY
              SplatHammer
              Thanks for the tip! I will take a look at that.
