Help required with firmware updates please.
  • Bought my duet 2 board from E3d and it arrived yesterday it appears that I have a pretty old board that needs some updates.
    I have looked and read over and over the contents of updating etc on the Duet 3d documents and have concluded I am thick as after 5 hours Im still nowhere!
    I'm generally pretty good with this kind of thing however if I could have a nudge in the correct direction please would be much appreciated.
    RepRapFirmware for Duet 2 WiFi/Ethernet Version 2.02(RTOS) dated 2018-12-24b1<LF><LF>Executing config.g...Error: Bad command: FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!<LF>WiFi module is disabled<LF>Warning: Heater 0 appears to be over-powered. If left on at fulWiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
    M122
    === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-917NK-F2MS4-7J9FA-3SJ6J-TZUDG<LF>Used output buffers: 1 of 20 (1 max)<LF>=== RTOS ===<LF>Static ram: 25524<LF>Dynamic ram: 98840 of which 0 recycled<LF>Exception stack ram used: 256<LF>Never used ram: 6452<LF>Tasks: NETWORK(ready,1300) HEAT(blocked,948) MAIN(running,3868) IDLE(ready,200)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:01:19 ago, cause: power up<LF>Last software reset details not available<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 37.5, current 40.9, max 41.1<LF>Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no<LF>Driver 0: ok, SG min/max not available<LF>Driver 1: ok, SG min/max not available<LF>Driver 2: ok, SG min/max not available<LF>Driver 3: ok, SG min/max not available<LF>Driver 4: ok, SG min/max <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
    m115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1<LF>ok<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>WiFi reported error: no known networks found<LF>WiFi module is idle<LF>
  • It seems that you're running the 2.02 firmware just fine. what you don't seem to have is a valid config.g file.
    I would follow the guide for getting started (https://duet3d.dozuki.com/c/Getting_Started)
    Specifically, set up at least network connectivity (https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7)
    Once that's done, then you can go to the RRF configurator tool (Link in the first report.) to create a set of configuration files, which you can then upload using the web control over the network. So far it looks like you'\re connected to USB only power, with no Vin (power good: no)
    If you don't want to connect to the network for whatever reason, you can unpack the configuration files onto the SD card in the /sys folder.
  • Hi many thanks for you help very much appreciated have just successfully gained access to the duet via ip address so im a happy chap now.
    I was beginning to get a bit self doubting but got there in the end thanks again!
    Any of my files need updating ?
    Firmware Name:
    Firmware Electronics:
    Firmware Version:
    2.02(RTOS) (2018-12-24b1)
    WiFi Server Version:
    1.21
    Web Interface Version:
    1.21
  • You schould update Web Interface Version to 1.22.6 and WiFi Server Version: 1.22 to be full up-to-date and compatible with 2.02 firmware version. Best just upload the full zip 2.02a
  • I am quite happy with the DWC v2.0.0RC3. You will want at least the DWC v1.22.6 if for no other reason than bug fixes. The Wifi server v1.22 is also good to have, it fixes a bug that the DWC v2.0.0 seems to tickle, though the 1.22.6 probably won't.
    Glad you got it sorted!
