    DWG drive configuration and Config.g not congruent
    Duet Web Control
    • FrancescoITAundefined
      FrancescoITA
      Hello everyone,
      I wanted to know if anybody found the same problem ...
      I have activated the endstop on the stall of the motors, everything works fine but the report of the DWG to the drive configuration section does not seem to me to huggle the configuration that I created.
      it seems that E0 and E1 are exchanged
      What did I do wrong?
      thank you in advance
      M569 P0 S1
      M569 P1 S1
      M569 P2 S0
      M569 P3 S0
      M569 P4 S0
      M584 X0 Y1 Z2:4 E3 U4
      M350 X256 Y256 Z256 E256 U256 I0
      M92 X1601.00 Y1603.00 Z6400.00 E7090.00 U6400.00
      M566 X540.00 Y540.00 Z18.00 E252.00 U18.00
      M203 X19980.00 Y19980.00 Z480.00 E1980.00 U480.00
      M201 X1000.00 Y1000.00 Z250.00 E2000.00 U250.00
      M906 X1200.00 Y1200.00 Z1200.00 E480.00 U1200.00 I10
      M84 S20
      M208 X-25 Y0 Z-1.75 S1
      M208 X220 Y240 Z240 U240 S0
      M574 X1 Y1 S0
      M915 Z S4 F0 H100 R0
      M915 U S4 F0 H100 R0
      M574 Z1 S3
      M574 U1 S3
        It looks to me that the E0 label in that DWC screen should read U, and the E1 label should read E0. Which version of DWC is this?
          FrancescoITA
          @dc42 said in DWG drive configuration and Config.g not congruent:
          DWC 1.22.6
          FW 2.02(RTOS) (2018-12-24b1)
            dc42 administrators @FrancescoITA
            @francescoita, thanks. This is @chrishamm's area, but he is unavailable for a few days. Also he is more focused on DWC 2.0 now.
              FrancescoITA
              OK thanks
              I take this opportunity to ask you how to solve another problem I have encountered.
              When I make the home if the U axis arrives at the stall it also blocks the Z by not completing the home correctly.
              the result is that the U axis (drive4) is in the correct position and the Z axis (drive2) remains higher
                @francescoita said in DWG drive configuration and Config.g not congruent:
                Please start a new thread for this problem, and in it explain your configuration.
