FTP file transfer to Duet
Hi
I wanted to copy a filament directory from my PC to Duet using Filezilla (max 1 connection) nad the directory is created but with empty files.
I don't like to switch between files from another filament, and copy and paste text in the DWC.
However it seems i cannot copy the file sover with ftp
Then i tried DWC (2) but dropping files on 'upload filament configs' places them in the top folders(together with the filament folders)
After a couple of drag and drops in Filezilla unload and config were copied ok but I never manged to copy load.g
Very confused how this is supposed to work.
I woul dbe nice to have a 'copy filament' in DWC.So ou can copy the scripts and just make some changes instead of starting from scratch for every new filament
I've reported this empty file over FTP problem before, so you're not the only one.
Thanks... I did search for ftp but didn't see that post
