G32 problems, adjusting the wrong way
Hi
I've been trying to setup bed leveling using 3 leadscrews and 3 steppers connected to it's own driver but I can't get it to correct in the right way.
It seems like it's adjusting backwards or not att all, is there something wrong with my setup?Here's my config.g
; Drives M584 X0 U6 Y1 Z2:4:5 E3 ; set 3 Z drivers and add one U driver M569 P0 S1 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S0 ; Drive 4 goes backwards M569 P5 S0 ; Drive 5 goes backwards M569 P6 S1 ; Drive 6 goes forwards M669 K0 Y1:1:0:-1 ; set Y to react with X and U M671 X490:490:10 Y0:490:200 S4 ; leadscrews at rear right, middle left and front right M350 U16 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 U80.00 X80.00 Y240.00 Z1066.67 E420.00:420.00 ; Set steps per mm M566 U900.00 X900.00 Y900.00 Z40.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min) M203 U10000.00 X10000.00 Y10000.00 Z750.00 E1200.00:1200.00 ; Set maximum speeds (mm/min) M201 U800.00 X800.00 Y800.00 Z50.00 E250.00:250.00 ; Set accelerations (mm/s^2) M906 U1000.00 X1000.00 Y1000.00 Z1000.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
Here's my bed.g
G28 ;home G30 P0 X490 Y0 Z-99999 ; probe near a leadscrew G30 P2 X490 Y390 Z-99999 ; probe near a leadscrew G30 P1 X10 Y200 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
This is the result of 2 G32 after each other:
G32
Leadscrew adjustments made: 2.242 1.998 -1.813, points used 3, deviation before 2.042 after 0.000G32
Leadscrew adjustments made: 2.278 -1.899 1.916, points used 3, deviation before 2.062 after 0.000 -
Check that you have specified the leadscrew XY coordinates in M671 in the same order as you specified the corresponding Z motor driver numbers in M584.
@dc42 Yes they should be correct.
@dc42 I've tripple checked both the config.g and bed.g now and I can't find anything wrong.
It seems like all the steppers are calibrating the same amount, so the bed just get's worse for every G32.. -
@haggan90 said in G32 problems, adjusting the wrong way:
It seems like all the steppers are calibrating the same amount, so the bed just get's worse for every G32..Those are exactly the symptoms of having the M671 coordinates not listed in the same order as the Z drivers in M584.
@dc42 I think so to, but somehow I can't get it to work.
Ok so here's my config.g again:; Drives M584 X0 U6 Y1 Z2:4:5 E3 ; set 3 Z drivers and add one U driver M569 P0 S1 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S0 ; Drive 4 goes backwards M569 P5 S0 ; Drive 5 goes backwards M569 P6 S1 ; Drive 6 goes forwards M669 K0 Y1:1:0:-1 ; set Y to react with X and U ; Defining X and Y coordinates of the leadscrews M671 X580:580:-80 Y0:490:200 S5 ; leadscrews at front right, rear right and middle left
And here's how all is connected:
Imgur -
I dont know if it matters, but your probe point numbers are not in "logical" order, you have P0, P2, P1 for some reason.
The order of the probe points in bed.g doesn't matter. What does matter is:
The bed moves the right way. Users with beds that move in the Z direction sometimes get this wrong; on these printers, +Z moves the bed down.
The order of coordinates in M572 matches the order of the Z drivers in M584. According to your config.g, driver 2 (Z motor output) drives the leadscrew at X=580 Y=0, driver 4 (E1 output) drives the leadscrew at X=580 Y=490, and driver 5 (E2 motor output on the DueX) drives the leadscrew at X=-80 Y=200. Is that correct?
@dc42 Yes that is correct, and the bed moves in +Z when it goes down.
Can you see all 3 leadscrews moving when it makes the correction? It may help to reduce the Z movement speed in M203 to make it easier to watch them.
Is 750mm/min Z speed (in your M203 command) achievable on your printer?
@dc42 Yes, all 3 are moving when it makes the correction, but I'm not sure if they are movin the exact same distance.
You can clearly see that the left one, the one who is alone, should adjust in -Z (move bed up) but instead it's adjusting in +Z (moves bed down).750mm/min should be possible. I had it set to 500mm/min at first but then my BlTouch were hitting the bed after probing (the bed was to slow to move down from the probe after probing).
@dc42 Any clues on what's wrong?
I'm sorry, I am baffled. Everyone else who reported similar issues had the motors orders not the same in M671 as in M584. In your case, it looks as though the first motor correction didn't happen at all, and the other two motor corrections were double the correct amount.
What happens if you change S3 on your final G30 command in bed.g to S-1 and run G32 several times? That will display the bed probe height errors. Then change it back to S3, run G32 and see what the corrections are, then go back to S-1 to see the new height errors.
@dc42 Ok I just did that, this is the results:
First I did G32 with S-1 4 times.G32 bed probe heights: 1.849 -1.364 1.682, mean 0.722, deviation from mean 1.477
G32 bed probe heights: 1.748 -1.340 1.683, mean 0.697, deviation from mean 1.441
G32 bed probe heights: 1.760 -1.335 1.593, mean 0.673, deviation from mean 1.422
G32 bed probe heights: 1.729 -1.408 1.605, mean 0.642, deviation from mean 1.451Then one time with S3
Leadscrew adjustments made: 2.320 2.124 -1.952, points used 3, deviation before 1.581 after 0.000Then one more time with S-1
G32 bed probe heights: 1.127 -1.914 1.042, mean 0.085, deviation from mean 1.414Is the probe values in the same order as the probing? The first value is the first probing?
The height errors are listed in the order of G30 probe points P0 P1 P2.
Try swapping the P2 and P1 parameters on your two G30 lines (you can leave the coordinates alone), so that it stores the points in the order P0 P1 P2. I don't think the order should matter, but people usually probe in the order P0 P1 P2 not P0 P2 P1.
Can you confirm that you are running a recent firmware version?
@dc42 said in G32 problems, adjusting the wrong way:
They were in the order P0, P1, P2.
But I found something that might cause the problem, I've forgot to remove the values for E1(Drive 4) in M92, M566, M203, M201 and M906. Do you think this might be it? -
@dc42 I just can't get this to work.. it refuses to calibrate the last stepper in the right way.
It seems like it's working for 2/3 steppers.
This is my last 3 results:21:11:40G32
Leadscrew adjustments made: 1.081 1.187 -3.137, points used 3, deviation before 1.541 after 0.000
21:07:11G32
Leadscrew adjustments made: 1.447 1.558 -2.405, points used 3, deviation before 1.336 after 0.000
21:06:49G32
Leadscrew adjustments made: 2.048 2.189 -1.888, points used 3, deviation before 1.492 after 0.000 -
doesn't anyone have any ideas what's wrong here? =/
Which firmware version are you using? I have 2 reports that this function is broken in the 2.03beta1 release.
@dc42 Yes I'm using the 2.03 Beta, the newest firmware.
