    Repetier gets constant messages if Duet Web Control is connected
    Firmware installation
    • James
      James last edited by
      If I have my printer connected in the Duet Web Control, my Repetier-Host log updates constantly, showing lines like this:
      10:20:09.914 : Request: status?type=1 fragment 2147483648
      10:20:09.914 : Resp 2147483648: 000100c8 0000019c {"st…s
      10:20:09.930 : Request: reply fragment 2147483648
      10:20:09.930 : Serving client 1 of 1
      10:20:09.930 : Resp 2147483648: 000000c8 00000079 FIRM...s
      10:20:10.194 : Request: status?type=2 fragment 2147483648
      10:20:10.195 : Resp 2147483648: 000100c8 00000327 {"st...s
      10:20:10.484 : Request: status?type=1 fragment 2147483648
      10:20:10.484 : Resp 2147483648: 000100c8 0000019c {"st...s
      10:20:10.763 : Request: status?type=1 fragment 2147483648
      10:20:10.763 : Resp 2147483648: 000100c8 0000019c {"st...s
      10:20:11.038 : Request: status?type=1 fragment 2147483648
      10:20:11.038 : Resp 2147483648: 000100c8 0000019c {"st...s
      This happened out of the box, so I updated to the latest versions of everything:
      Firmware: 1.17e
      WiFi Server Version: 1.03 (ch fork)
      Web Interface Version: 1.12-RC1
      But this did not change the behavior. Anyone know why this happens and if it can be fixed?
      Thanks,
      James
      • Jackal
        Jackal last edited by
        Try updating to Duet Web Control 1.14a
        https://github.com/dc42/RepRapFirmware/blob/dev/Release/Duet-WiFi/Stable/DuetWebControl-1.14a.bin
        • James
          Thanks – I didn't realize I didn't have the latest. But, I updated and it still does the same thing. Below is a new sample, in case these codes actually mean something to someone πŸ™‚
          James
          11:08:37.146 : Resp 2147483648: 000100c8 00000039 {"er...s
          11:08:37.167 : Request: status?type=2 fragment 2147483648
          11:08:37.167 : Resp 2147483648: 000100c8 00000328 {"st...s
          11:08:37.178 : Request: config fragment 2147483648
          11:08:37.179 : Resp 2147483648: 000100c8 00000267 {"ax...s
          11:08:37.191 : Request: filelist?dir=0:/sys fragment 2147483648
          11:08:37.191 : Resp 2147483648: 000100c8 00000296 {"di...s
          11:08:37.200 : Request: reply fragment 2147483648
          11:08:37.200 : Resp 2147483648: 000000c8 00000000
          11:08:37.558 : Request: status?type=1 fragment 2147483648
          11:08:37.558 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:37.863 : Request: status?type=1 fragment 2147483648
          11:08:37.863 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:38.178 : Request: status?type=1 fragment 2147483648
          11:08:38.178 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:38.489 : Request: status?type=1 fragment 2147483648
          11:08:38.489 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:38.791 : Request: status?type=1 fragment 2147483648
          11:08:38.792 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:39.097 : Request: status?type=1 fragment 2147483648
          11:08:39.098 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:39.374 : Request: status?type=1 fragment 2147483648
          11:08:39.374 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:39.647 : Request: status?type=1 fragment 2147483648
          11:08:39.647 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:39.923 : Request: status?type=1 fragment 2147483648
          11:08:39.923 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:40.198 : Request: status?type=2 fragment 2147483648
          11:08:40.198 : Resp 2147483648: 000100c8 00000328 {"st...s
          11:08:40.486 : Request: status?type=1 fragment 2147483648
          11:08:40.486 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:40.757 : Request: status?type=1 fragment 2147483648
          11:08:40.758 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:41.045 : Request: status?type=1 fragment 2147483648
          11:08:41.045 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:41.319 : Request: status?type=1 fragment 2147483648
          11:08:41.319 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:41.592 : Request: status?type=1 fragment 2147483648
          11:08:41.592 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:41.865 : Request: status?type=1 fragment 2147483648
          11:08:41.865 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:42.137 : Request: status?type=1 fragment 2147483648
          11:08:42.137 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:42.408 : Request: status?type=1 fragment 2147483648
          11:08:42.409 : Resp 2147483648: 000100c8 0000019c {"st...s
          11:08:42.684 : Request: disconnect fragment 2147483648
          11:08:42.684 : Resp 2147483648: 000100c8 00000009 {"err":0}
            Repetier Host unfortunately turns on debug output by default. I don't know why, it seems a daft thing to do to me. You can turn it off by going to the console and pressing the Info and Errors buttons to turn them off.
            • James
              Well, that's weird. I can turn everything off, and it still happens. No matter what combination I select of Commands, Infos, Warnings, Errors, or ACK, it still shows up. I'm using v1.6.2, which it says is the most current.
              What are these messages anyway?
              Thanks,
              James
                Those are summaries of the comments between the WiFi module and the main processor. Sending M111 S0 should stop them if Repetier doesn't intercept that command.
                • James
                  Sending M110 S0 from the Duet Web Control stops the messages in Repetier, until you send another command. E.g., after I saw that it stopped, I tried M114 and M115 from Repetier just to see if the log still worked, and then the messages start again.
                  Anyway, not worth taking up more of your time – it doesn't hurt anything except the ability to see the logs, and if I want to I can always disconnect the Duet Web Control temporarily while in Repetier.
                  Thanks,
                  James
