    BUG Report: wrong offset for 1st tools change
    Firmware developers
    • chernogorskyundefined
      chernogorsky
      Hi, having a multi extruder setup
      and have found that in some condition tools offset does not apply for the 1st tool (only initial tool change. after a loop evr is ok)
      So, my setup:
      T0, T1, T2 with different offsets (G10)
      after reboot, select T1
      in that case tool's offsets does not apply
      after a cycle (for example T-1, T1) they do
      2.02(RTOS) (2018-12-24b1)
        Please provide a config.g file and a sequence of moves that demonstrates this issue.
          chernogorsky
          upgraded to 2.03beta
          cant reproduce by now. will update if hit it again
            OK thanks.
