controlling two heaters in one extruder
  • Hi all,
    I was trying to control two heaters mounted on one extruder.
    I need their temperature to be different from each other (e.g. the first heater 120 degrees and the second heater 220 degrees).
    I have also mounted a fan to cool the first heater in case its temperature was raised above the set value.
    What is the best way to configure this setup using the firmware configuration tool??
    To configure the temperatures for two or more heaters on a single tool, use the G10 command to set the temperatures. For example:
    M563 P0 H1:2 D0 ; tool 0 uses heaters 1 and 2
    G10 P0 S120:220 ; set heater 1 to 120C and heater 2 to 220C
  • @dc42 many thanks for your reply, I will try it.
    and regard using the cooling fan to cool the heater if it overheated
    I tried to use this command
    M106 P0 S1 I0 F500 H2 T120
    However, I have noticed that once I give the printer a job to print it stops executing this command. should I add any commands in the slic3r?
    Thanks
    @shaqour said in controlling two heaters in one extruder:
    When you configure a fan to be thermostatically controlled like that, you can't control the fan manually unless you first disable thermostatic control.
  • @dc42 can you please advise me what command is used to trigger the fan based on the temperature of the heater?
    The command you gave before:
    will turn fan 0 on when heater 2 temperature is 120C or more.
    Note, Fan 0 output is normally used for the print cooling fan. I suggest you use fan 1 or 2 fr the hot end cooling fan.
