    How to get eclipse use the correct Pins_*.h?
    Firmware developers
    • wilrikerundefined
      wilriker
      I have everything for RRF setup in eclipse. It is working. I can compile successfully and get working binaries out of it. There is just one annoying thing that I cannot get to work correctly:
      It only looks at Pins.h for the feature flags like SUPPORT_WORKPLACE_COORDINATES or SUPPORT_LASER and all of the others.
      In my case I use Duet2_RTOS as the active build configuration and to all I can see it should recognize src/DuetNG/Pins_DuetNG.h but it doesn't.
      This leaves me with sometimes hard to navigate code parts where something is enclosed in #ifdef XXX ... #endif and eclipse evaluates XXX to 0 because that's the value in Pins.h but in Pins_DuetNG.h it is redefined to be 1. And it just won't let me navigate code in this case.
      What could I check/do about that?
      Manuel
      My Tool Collection
      • wilrikerundefined
        wilriker
        Found it. Although the indexer was enabled in global settings with correct values I had to go to
        Project -> Properties -> C/C++ General -> Indexer
        and tick Enable project specific settings.
        All of the so called project specific settings are absolutely identical to the ones of the global indexer but now it works. 🤦
        Manuel
        My Tool Collection
          It works for me. What version of Eclipse are you using? I use Version: 2018-09 (4.9.0).
          There is a setting in Eclipse to rebuild the index when you switch build configuration, and I have that selected.
          • wilrikerundefined
            wilriker @dc42
            @dc42 I am using Version: 2018-12 (4.10.0) but it never worked in any version for me. I rebuilt the index about a million times already. Also it shows the src/DuetNG folder as excluded in the Project Explorer even though it obviously includes it when compiling because it builds the binaries without any issues.
            I also tried to add the folder explicitly to
            Project Properties -> C/C++ General -> Preprocessor Include Paths, Macros etc. -> CDT User Setting Entries
            in all of the available forms. It just does not want to read this file.
            Switching build configurations back and forth also did not help. I mean, I can work with it and found my ways around it but it would be nicer not to have to use global search to find things that I cannot jump to because they are inside #ifdef blocks.
            Manuel
            My Tool Collection
              I sometimes find that in order to get the correct folders shown, I have to select another configuration, then go back to the one I want.
              • wilrikerundefined
                wilriker
                Manuel
                My Tool Collection
