    M453 Issue after homing
    Firmware installation
    837
    • Ryan Lock
      Ryan Lock last edited by
      With the M453 command in the config.g file, with no parameters. After homing the machine, the X-Axis cannot be jogged as it gives an out of limit error. Even though the command would be well within the limit of the machine.
      However if you then to proceed to jog the Y-Axis once. Then proceed to apply the same X-Axis jog command which gave the error previously it now works.
      Removing M453 from config.g, and the issue goes away.
      Firmware version 2.02 RTOS.
      Ryan Lock
        I think this is related to a similar issue that was reported for laser cutter mode. I fixed that in the 2.03 beta firmware. So please try 2.03beta2.
        Ryan Lock 1 Reply Last reply Reply Quote 0
        • Ryan Lock
          Ryan Lock @dc42 last edited by
          @dc42 Sorry just got round to testing 2.03Beta2, and the bug is still present.
          • Ryan Lock
            It also affects the Z-Axis. And stops homing of individual axis for the X and Z. For example:
            G91 ; relative positioning
            G1 S1 Z94 F1500 ; move quickly to Z axis endstop and stop there (first pass)
            G1 Z-3 F2400 ; go back a few mm
            G1 S1 Z94 F300 ; move slowly to X axis endstop once more (second pass)
            G90 ; absolute positioning
            Gives an outside machine limits error. Same for the X-Axis. But on the Y-Axis it works, even though it is the same code, except Z replaced with Y.
            Ryan
              I'm sorry for the delay in responding, it's been very hectic here with multiple deadlines to meet. I will look into this on Saturday.
                dc42 administrators @dc42 last edited by
                @Ryan-Lock, please post your config.g file so that I can try to reproduce this.
                • Ryan Lock
                  Hi David,
                  Please see attached. I have also attached our homeall file.
                  Best Regards
                  Ryan Lock
                  1_1552643858526_config.g 0_1552643858525_homeall.g
                    Thanks. I've reproduced the problem, although with 2.03beta I don't get the out-of-limit message, it just refuses to jog X and Z (in the negative direction) until I jog Y. I'll fix this tomorrow. My guess is that the fix I put in beta 2 wasn't quite right.
                    • Ryan Lock
                      Ryan Lock last edited by Ryan Lock
                      Hi David
                      Not a problem. Yes i did notice it didn't display the error but refused to move. But if i remember correctly switching back to the original web control it showed the error. So i presumed that was a bug in the new gui.
                      A fix would be great.
                      Best Regards
                      Ryan Lock
                        Hi Ryan,
                        I have located the problem. Your Y steps/mm is an unusual value, and as a result the Y axis limit of 520mm does not round-trip to motor positions and back again exactly. This results in the user Y position after homing being very slightly greater than 520, although you can't see that because the value is rounded to 1 decimal place for display.
                        To fix this, I propose to allow commanded positions to exceed the axis limits by 0.05mm. Do you consider this acceptable?
                        Meanwhile, a workaround is to add either G1 Y520 or G92 Y520 in your homeall.g and homey.g files after the Y axis has been homed.
                          PS - is your Y steps/mm exactly 53 and 1/3 mm? If so then there is a simpler workaround: change the Y steps/mm from 53.33 to 53.33333 . With this value, the rounding error does not occur.
                          • Ryan Lock
                            Hi David,
                            Sorry for the late response on this.
                            Yes it is 53 1/3 exactly.
                            Changing it to 53.333333 did allow movement from the homed position on all axis. However when getting to the other end of the travel, you could never get to your absolute minimum on the axis with 53.333333.
                            So putting the G92 command in the homing files is the best solution to this.
                            Best Regards
                            Ryan Lock
                              Ryan, please try firmware 2.03beta3 which I released recently. it implements the additional tolerance that I mentioned in an earlier reply.
