Duet Wifi independent dual X & Y Axis + Endstops configuration
Hey,
I'm building a MPCNC and need help with the duet wifi configuration. I have the following hardware:
2 Motors X + 2 Endstops
2 Motors Y + 2 Endstops
1 Motor ZI have the latest Duet Wifi v1.04. I have just a basic knowledge and need help how to set up the dual axis in the firmware. I connected the second Y motor to the E0 and the second X motor to the E1 slot on the duet. The same for the endstops.
Please help me how to set it up correctly. Thanks.
I recommend to start here : https://duet3d.dozuki.com/
Here's how to do it for dual Z motors and endstops: https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en. Use the same principle for dual X or dual Y motors and endstops. That is, split the 2 motors into separate axes during homing, and rejoin them after homing.
@dc42 said in Duet Wifi independent dual X & Y Axis + Endstops configuration:
Were you able to get this configuration up and running?
@mtcl The setup should work. Please start a new thread and include your setup details and configuration files.
