    Velocity Ramping
    Laser Cutters
    3.6k
      dc42 administrators @DarkAlchemist
      @darkalchemist said in Velocity Ramping:
      To everyone I keep forgetting to check back on this thread because this is the first forum I have ever used that didn't have a send email for replies option. If it does I couldn't find it.
      You haven't found it. Click on your user icon, which is at the top right of the top bar if you are viewing this forum on a PC, then select Settings.
      DarkAlchemistundefined 1 Reply Last reply Reply Quote 0
        Getting back to the main deal breaker is the lack of the Velocity Ramping which the Ruida controller has.
        Velocity ramping is scheduled to be implemented very soon. To give me an idea of the required granularity, can you tell me what are typical XY accelerations and typical XY movement speeds when the laser is on?
        • DarkAlchemistundefined
          DarkAlchemist @dc42
          @dc42 said in Velocity Ramping:
          Thank you as most forums have it on the post itself so each post can have notifications or you can unclick it to turn it off for that post.
            DarkAlchemist @dc42
            There is no typical speed or acceleration but I can tell you the range and that is 0-500mm/s (Chinese type lasers) or up to 1000mm/s on the big boy lasers. Accelerations run from 0-20k where most are 6-12k for the Chinese type laser machines and for the big boys I do not know but think they are the same range.
              Thanks. What I am wondering is at what intervals the PWM needs to be adjusted, given that true continuous adjustment is not practical. With very high accelerations, velocity ramping may not be needed at all, and I doubt that the sort of laser cutter that would be driven by a Duet would reach anything like 1000mm/sec.
              If we take a more reasonable figure of 300mm/sec commanded speed and 3000mm/sec^2 acceleration, then full speed will be reached in 100ms. If we change the PWM at 10% intervals, that means we should adjust the PWM at intervals of 10ms or less. Does that sound reasonable?
              LightBurnundefined 2 Replies Last reply Reply Quote 0
              • LightBurnundefined
                LightBurn @dc42
                @dc42 For vector marking, 10% sounds like a reasonable starting point.
                It might be worth having a parameter to specify whether to use constant or variable power (GRBL does this), and the higher end DSP controllers let me specify a low and high power value to ramp between, which is handy for CO2 systems where the ionization point gets higher as the tube power goes up.
                I chatted with Tony yesterday at MMRF about some ideas I have for dealing with raster data, and he suggested going straight to the source. If you're open to it, I'd love to talk to you about raster data - I have an implementation idea that I believe to be "minimally invasive" for the firmware, but would allow for much less compute overhead. I have a Duet 2 Wifi waiting for me at home and I'd like to look at supporting it in LightBurn soon.
                  LightBurn @dc42
                  @dc42 - I’ve implemented my raster clustering idea in Smoothieware and can now easily raster 0.1mm pixels at 200mm/sec without hiccups (previous limit was 80mm/sec). I’m going to do some more tests, and make some small changes to the implementation still, but it was simple to add.
                  • DeltaConundefined
                    DeltaCon
                    Since I am planning a laser CNC build, I would very much like to hear about any progress concerning the raster capabilities of a duet controller, and the connectivity between Lightburn and Duet. Thanks!
                    If you think trial and error is dangerous, try routine. That's even more so!
                      RepRapFirmware works with LighBurn. Raster clustering has been somewhat delayed because of Duet 3, RepRapFirmware 3 and conditional GCode, but is scheduled for implementation in RRF 3.02.
                      • DeltaConundefined
                        DeltaCon
                        Thanks DC42. If I understood correctly from other threads and forums, pixel (say: 0.1mm) needs to be defined in a single gcode line, and that poses a bottleneck on the execution speed. Is that only relevant on quickly moving CO2 machines, or is that also a problem for the usually lower speeds that a diode laser needs? I am going for a diode laser, would a Maestro board suffice for that, like the firmware acts as it is at this moment? Or would it suffice after raster-clustering has been implemented?
                        • DeltaConundefined
                          DeltaCon
                          Bump for the previous post (not only intended for David to answer 😉 )
                          And also:
                          Since my Laser CNC is much simpler that a 3d printer (no heaters, no fans, no multiple extruders or anything) I am thinking about the Duet Maestro. Are there any thinkable reasons to NOT do that and go for a Duet Ethernet? Perhaps in terms of computational power, memory limits that might prevent future firmware updates (sooner that other Gen2 Duets)?
