    Duet 2 controlling a cnc spindle / VFD via pwm
    CNC
    • GazzarUK
      GazzarUK last edited by
      Anyone got details on how this be possible?
      already got the PWM signal to Voltage Converter Digital-Analog PLC
      looking to conect it to my VFD and my Duet to control spindle speeds.
      Thanks for looking
        Which PWM to voltage converter did you get?
        • GazzarUK
          https://www.amazon.co.uk/gp/product/B075F79TKD/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
            Your first problem is this:
            PWM signal input level range:4.5V to 10V peak level jumper inserted at 5V . This class level signal mainly for conventional industrial control card ( such as MACH3 board ), 5V for CPU interface.
            If you have a DueX in your system then you can get a 5V signal from one of the servo pins. Otherwise, only 3.3V signals are available. You will need to identify the optocoupler input series resistor on that PWM converter and reduce its value (e.g. by soldering another SMD resistor on top of it) to make the input 3.3V compatible.
            • A Former User
              A Former User last edited by
              Could he use a 5V fan output if hes got one spare?
                dc42 administrators @Guest last edited by
                @bearer said in Duet 2 controlling a cnc spindle / VFD via pwm:
                Yes, or a spare heater output.
