    HOW TO INSTALL RRF IN SAME70 XPLAINED WITH RADDS?
    Firmware installation
    • pepito
      pepito last edited by
      HOW TO INSTALL RRF IN SAME70 XPLAINED WITH RADDS?.PLEASE
        We have never built or run that combination. The SAME70-XPLD support was added when we were prototyping parts of Duet 3. We left that build configuration in the project for the benefit of users such as yourself who may wish to adapt it to work with SAME70-XPLD plus a particular shield with stepper drivers, heater mosfets etc.
        To complete the port you would need to do at least the following:
        1. In file Pins_SAME70xpld.h fill in the pin number tables with the correct pin definitions for RADDS on a SAME70XPLD.
        2. Modify the 3 functions at the end of file Platform.h to allocate one bit per step pin and write the correct bits to the correct ports.
        pepito 1 Reply Last reply Reply Quote 0
        • pepito
          pepito @dc42 last edited by
          @dc42 but, how install rrf?
            When you have built a compatible version of RRF, you can install it via the USB port using Bossa 1.9.1.
            • pepito
              @dc42 Thanks
