    Averaging readings while grid probing
    Firmware wishlist
    grid probing z-probe consistency
    • rhidgbakundefined
      rhidgbak
      Setting the tolerence (SXX) in the M558 command to a negative value currently forces the average to be used (and give a warning--not an error.)
      However, this does not seem to be respected when doing mesh grid probing. (works fine for G28 homing etc.) When mesh grid probing after setting "M558 ... S-0.2", it stops and reports an error.
      Can this functionality be respected by the grid probing (i.e., setting tolerance in the M558 to a negative value and NOT have an error stop the mesh grid process)?
      Looking at the source, it looks like the two situations are handled differently.
      I seem to get really good results from by BLtouch using z-probe averaging (on a Marlin machine) so I'd like to do this with my duet3d wifi.
      Thanks in advance for considering.....
        Which firmware version are you running? The current firmware (2.02, or 2.03beta) should already behave the way you want.
