    Turn on a temp. controlled fan by gcode
    Duet Web Control
    • Knurb
      Knurb last edited by
      Is there a possibility to controll a temp controlled fan "manually" by Gcode or Slider in the webUI?
      Reason why, I have configured a temp sensor for my chamber. Two fans are switched on, when temperature reaches 60 degrees.
      It works fine, but now id like to switch these fans on after print finished. (via end script)
      Thanks
      • aidar
        aidar last edited by aidar
        Its not possible to control thermostatically controlled fans manually. But you can disable thermostatic control in your end script (or in macro, and call that macro in end script) and then turn the fan on. Of course you have to remember enable thermostatic control before next print (via start script or macro for example).
        • Knurb
          OK, thank you. I'll give it a try.
