    Bossa Program Port?
    Duet Web Control
    • marsian999
      marsian999 last edited by
      hi all
      i just got a duet wifi board yesterday
      and when i try to connect it with YET, i cant find my duet on the new terminal, all i find is "COM11 - BOSSA Program Port"
      so then i cant even turn on the wifi on duet....
      what should i do ?
      thanks all
        That means that there is no firmware loaded on your Duet. If you bought it from a genuine Duet3D reseller, and assuming you didn't fit the Erase jumper on the board to erase the firmware, please report it to your reseller as it may indicate that the board hasn't been tested.
        The board can be programmed with firmware using the procedure here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
        • marsian999
          thanks that work
