    Problems loading height map
    Firmware installation
    1165
    • percar
      percar last edited by
      When I try to load a height map using G29 S1 , I get the following error
      Error: Failed to load height map from file heightmap.csv: number expected at line 3 column 201
        Please post your heightmap.csv file.
        • percar
          RepRapFirmware height map file v1 generated at 2017-02-04 20:40, mean error -0.20, deviation 0.08
          xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
          20.00,540.00,30.00,250.00,-1.00,20.00,27,12
          -0.162, -0.187, -0.157, -0.146, -0.152, -0.147, -0.151, -0.166, -0.171, -0.183, -0.195, -0.209, -0.219, -0.221, -0.228, -0.231, -0.219, -0.213, -0.201, -0.207, -0.189, -0.182, -0.163, -0.141, -0.108, -0.096, -0.082
          -0.250, -0.276, -0.258, -0.251, -0.254, -0.239, -0.246, -0.234, -0.252, -0.227, -0.248, -0.247, -0.243, -0.241, -0.239, -0.221, -0.199, -0.181, -0.174, -0.171, -0.134, -0.111, -0.103, -0.089, -0.070, -0.059, -0.041
          -0.236, -0.254, -0.228, -0.216, -0.226, -0.231, -0.225, -0.234, -0.245, -0.254, -0.252, -0.267, -0.269, -0.263, -0.262, -0.262, -0.244, -0.241, -0.214, -0.211, -0.163, -0.142, -0.120, -0.085, -0.056, -0.007, -0.011
          -0.234, -0.268, -0.246, -0.236, -0.244, -0.231, -0.239, -0.238, -0.243, -0.257, -0.252, -0.257, -0.253, -0.241, -0.236, -0.222, -0.212, -0.184, -0.171, -0.153, -0.126, -0.093, -0.062, -0.031, -0.007, 0.014, 0.028
          -0.246, -0.252, -0.238, -0.228, -0.234, -0.228, -0.238, -0.252, -0.264, -0.277, -0.272, -0.291, -0.286, -0.287, -0.279, -0.277, -0.267, -0.248, -0.243, -0.231, -0.206, -0.178, -0.127, -0.086, -0.044, -0.019, 0.018
          -0.219, -0.256, -0.223, -0.220, -0.235, -0.225, -0.234, -0.233, -0.236, -0.246, -0.244, -0.250, -0.241, -0.229, -0.231, -0.214, -0.202, -0.177, -0.150, -0.128, -0.096, -0.071, -0.045, -0.020, 0.004, 0.016, 0.046
          -0.239, -0.256, -0.234, -0.233, -0.234, -0.243, -0.246, -0.250, -0.267, -0.283, -0.259, -0.291, -0.301, -0.289, -0.289, -0.281, -0.270, -0.255, -0.244, -0.228, -0.201, -0.173, -0.126, -0.088, -0.057, -0.013, 0.018
          -0.216, -0.262, -0.233, -0.236, -0.235, -0.233, -0.231, -0.233, -0.237, -0.247, -0.246, -0.243, -0.246, -0.239, -0.229, -0.214, -0.197, -0.175, -0.158, -0.132, -0.116, -0.083, -0.059, -0.029, -0.024, -0.001, 0.026
          -0.238, -0.247, -0.223, -0.221, -0.223, -0.241, -0.264, -0.265, -0.269, -0.288, -0.293, -0.295, -0.304, -0.311, -0.293, -0.303, -0.284, -0.266, -0.254, -0.245, -0.217, -0.179, -0.145, -0.109, -0.079, -0.052, -0.010
          -0.229, -0.252, -0.231, -0.226, -0.230, -0.229, -0.228, -0.228, -0.241, -0.252, -0.245, -0.251, -0.244, -0.242, -0.237, -0.232, -0.213, -0.196, -0.187, -0.182, -0.163, -0.137, -0.113, -0.089, -0.061, -0.039, -0.002
          -0.244, -0.242, -0.217, -0.223, -0.226, -0.239, -0.256, -0.245, -0.279, -0.293, -0.293, -0.301, -0.313, -0.317, -0.314, -0.286, -0.293, -0.278, -0.269, -0.253, -0.234, -0.195, -0.169, -0.137, -0.102, -0.064, -0.019
          -0.226, -0.250, -0.226, -0.219, -0.214, -0.223, -0.233, -0.233, -0.239, -0.241, -0.240, -0.264, -0.265, -0.255, -0.259, -0.250, -0.251, -0.238, -0.232, -0.223, -0.204, -0.186, -0.169, -0.137, -0.118, -0.079, -0.031
          • percar
            I should also have stated that I'm using 1.18beta1
            • percar
              Any Idea what is happening with the height map file. I installed Beta 2 but it is the same thing
                That's a long bed! My guess is that the large number of points along it (27) is causing the file line length limit to be exceeded. For now, try a larger grid spacing to reduce the number of points along the X axis.
                • percar
                  Thanks that solved the problem went from 20mm grid to 40mm
                    Fixed in 1.18beta3. Max number of points along the X axis is 25 in 1.18beta2 and earlier.
