Duet WiFi 0.85 vs 2.0
    Sink
    What size difference between the boards ?
    Are the dimensions listed somewhere?
    Thanks and Regards
      aidar
      https://duet3d.dozuki.com/Wiki/Hardware_Overview#main scroll down to see about old duets (0.6 and 0.85)
        The length, width and mounting hole positions are identical across all older Duets and the Duet 2 series. I think the SD card socket and USB socket positions are also the same. The Ethernet connector on the Duet Ethernet is not in the same position as on the Duet 06 or 085.
          Sink
          Beginning to think that I have a Duet 2 not 0.85.. I have 5 fan pins like the 2 docs instead of four like the 0.85.. I tried to login to the old account but no luck with login or changing password.. I purchased on Aug 2, 2017.. Do I have a Duet 2?
          Regards
            There should be some silk screened lettering on the board itself that indicates what it is. Do you see anything?
              You can also look at the stepper driver chips. If they are large square chips labelled TMC2660, it is a Duet 2. If they are smaller rectangular chips labelled A4982, it is a 085 (if there are 5 of them) or 06 (if there are 4).
              The exception is the Duet WiFi first prototype in my bottom drawer, which has A4892 drivers!
              undefined 1 Reply Last reply 6 Jul 2019, 20:39 Reply Quote 0
                Sink @dc42
                Yup ,, Its a 2 .. TMC2660 Chips .. and I see Duet v1.02 on the Board..
                Thanks
                4 out of 7
