    Power supply, Do I have enough wattage?
    • DallasHundefined
      DallasH
      This Is new to me, while i am quite able to do my Hard Parts machining/Conversion. and I do know some CNC milling G-code. The duet is quite a lot different than what i am used to working with.
      Right now i am in the final stages of my CubePro Redesign / Rebuild, and soon it will be programming time. can some one look at my component list Below. I have a feeling i may be light on power supply wattage. and is it a problem that my X and Y Axis, oriental motors are higher voltage than the rest? or is that just a matter of the max current setting?
      Thanks in advance.
      My printer Hardware:
      Print Heads:
      Dual Bondtech BMG-X2-M 3:1 gearing
      2x nema 17 1.8 step 18Ncm Holding Tq, 2.9V .7A
      2x 24vdc mosquitp fans .10A
      2X 24vdc part cooling fans .06A ea.
      2x Mosquito 450C thermistor
      2x Mosquito 24VDC 50 Watt Heater
      2x additional Blowers 12Vdc .25A
      Drives: 2X Z-axis Nema 17 1.8 step 45Ncm Holding, 2.7V , 1.68A
      1x Y-Axis Nema 17 .9 Step angle 81.9Ncm Holding 3.9V 1.5A Dual shaft, Drives left and right belts via jackshaft.
      1x X-Axis Nema 17 .9 Step angle 41.6Ncm Holding 3.2V 1.5A
      2x TR8x2mm pitch Lead Screws Direct drive
      3x 18Tooth GT2 drive pulleys
      4x NC Limit switch 2 wire "Cherry"
      Control Boards:
      Duet 2 Wifi
      Duex 2
      PT100 Daughter Board
      ThermoCouple Daughter Board
      Panelview 5I
      BL touch bed leveling sensor
      Heaters:
      1000 Watt silicone bed heater 120VAC 310mmx310mm
      2x PT100 bed temp sensors (Redundent Check if possible?)
      500 Watt RTD enclosure Chamber heater 120VAC
      2x Omron SSR
      control Panel cooling 2x Fans 24VDC .04amps
      Power supply: 200 Watts 8.3 amps
      Configuration:
      Duet2 Wifi: X & Y axis motors (2)
      E0 & E1
      Bed Heater SSR
      E0 & E1 Heaters
      X & Y limit switchs
      Mosquito Fans (2)
      Part Cooling Fans (2)
      Pt 100 Daughter Board (Bed Sensors 2)
      Duex2:      Z-Axis motors and endstops
      	    Chamber Heat RTD
      	    Chamber Heat thermocouple
      	    2 electronics cooling fans
      	    2 LED 18in strip Lights
        To calculate the total wattage you need, see https://duet3d.dozuki.com/Wiki/Choosing_the_power_supply#Section_Total_power_needed. Don't forget to include the power draw of the LED strips.
        • DallasHundefined
          DallasH
          I was hoping you would say that, as room in the electronics bay is close to being 100% full! this is the original 3D systems PS, and to get something bigger would be another 50mm x 25mm. I have moved all the electronics from the inside bottom to the outside rear.
          Thanks
          Dallas![alt text]0_1562564366338_Cubepro Rebuild and Redesign Duet 3d wifi and duex 2.jpg0_1562564457825_cubepro mod.jpg
            I edited my original reply, because although 200W would normally be more than enough for a dual-extrusion printer that uses an AC mains bed heater, I don't know the power draw of the LED strips.
