Bed autolevel and mesh compensation
It is still not clear for me after reading most of the wiki is my way of doing right or not.
Please take a look.I'm running corexy with double Z motors drivers (Z + E1).
before printing i'm doing:
- autolevel Z using two endstops
- calibrate screw using two points with G30 command using bltouch as Z probe
- enable mesh by G29 S1
calibration script:
G29 S2 ; disable mesh compensation
G90
G1 Z1 F6000
G1 X35 Y200 F9000
M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X5 Y200 Z-99999 ; probe near a leadscrew, half way along Y axis
M402
G1 X400 F9000
M401
G30 P1 X370 Y200 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
M402 ; retract probe (omit if using bltouch)G29 S1 ; enable mesh compensation
The problem I see is that if I do a paper check on nozzle I do see difference above 0.1mm across the bed
My assumption that mesh have to fix this but it is not -
At some point you need to re-establish the Z0 point, so perhaps after the leveling of the lead screws you need to add a single G30 probe at the center of the bed before you load the heightmap.
Do you mean this command?
G30 S-2
No, I mean just a regular G30.
@axillent said in Bed autolevel and mesh compensation:
calibration script:
G90
G1 Z1 F6000
G1 X35 Y200 F9000
M402
G1 X400 F9000
M401
G30
G29 S1 ; enable mesh compensation -
It would also maybe help to see how you are homing. Can you post your homeall and homez? And perhaps your config.g for good measure?
I see, thanks. Will try
it is still something is wrong
why Z is changing if just after homing I run G29 S1?
I do have G29 S1 in my homing scriptG29 S2 ; disable mesh compensation
G90
G1 Z1 F6000
G1 X35 Y200 F9000
G1 X400 F9000
G30 P1 X370 Y200 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motorsG1 X205 Y200 Z5 F9000
G30G29 S1 ; enable mesh compensation
Can you explain what you mean by Z changing?
