Using rotary encoder for filament monitoring
I have a rotary encoder that I want to use as a filament monitor for clog detection. I have been using the laser filament monitor and it has worked well so far but I have heard of problems depending on the type/color of filament used. Has anyone tried using a rotary encoder for this? Any advice on how I could go about wiring and configuring a rotary encoder for filament monitoring?
Hi @FairladyZ
I haven't seen anyone use one on here. They are meant to be releasing the magnetic sensor option shortly. I was hoping we were going to hear something about it last week but nothing as of yet.
Kind Regards,
Sam -
@samlogan87 said in Using rotary encoder for filament monitoring:
Hi @FairladyZ
Kind Regards,
SamWe finally have production housings for the magnetic filament monitors. We are running tests to check that they work OK with current firmware, also I am holding back releasing RRF 2.04 in case changes are needed.
@dc42 great news. I have been holding off getting a filament monitor or making one for these. Hopefully they are not too far away
Sam
@dc42 sorry to be a pain but is there any news on the magnetic filament sensor. I am doing a bit of a rebuild and would like to integrate it in. Apparently filastruder are selling a Duet one but I am not sure if it is the latest release.
Kind Regards,
Sam
@fairladyz said in Using rotary encoder for filament monitoring:
99p filament monitor
99p filament monitor againIt's still in use on my cartesian (diy i3 clone) and working well, although I had to set the parameters looser than I expected due to the error that accumulates with retraction and not actually knowing which way the encoder is moving when a transition comes through. I think to make this work well one would need to develop a model of the encoder in the duet firmware and predict the transitions based on the instructed filament movement.
