    Duet 2 Wifi - TRONXY Z Probe Woes:
    1.2k
    • Vetiundefined
      Veti
      @veti said in Duet 2 Wifi - TRONXY Z Probe Woes::
      what is the output of M558 without parameters
      please answer this question.
      • xxexxundefined
        xxexx
        M558
        Z Probe type 0, input 0, invert no, dive height 5.0mm, probe speed 0mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
        • xxexxundefined
          xxexx
          if i activate the probe via "m558 P5 I1" and the sensor is not triggered it says:
          • xxexxundefined
            xxexx
            M558
            Z Probe type 5, input 0, invert yes, dive height 5.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03
            and if it is triggered:
            M558
            So i guess my problem is "input 0"
            • Vetiundefined
              Veti @xxexx
              @xxexx said in Duet 2 Wifi - TRONXY Z Probe Woes::
              before you manually put in that command
              • xxexxundefined
                xxexx
                If i restart the board (sensor does not show red "1000" when triggered:
                M558
                • Vetiundefined
                  Veti
                  there must be something wrong with the lines you put in. Maybe hidden control characters
                  please delete the existing M558 lines completely and retype the M558 P5 I1 command by hand into the config.g. and check with M558 after restarting
                  • xxexxundefined
                    xxexx
                    I did exactly that - i commented the old m558 command and pasted "M558 P5 I1" into the config.g. Then i packed it into a new config.zip and uploaded it + restarted the board: sensor cannot be triggered.
                    Then i pasted and send "M558 P5 I1" manually - it works. (sensor lights up in the web configurator).
                    • Vetiundefined
                      Veti
                      I did exactly that
                      no you did not. please reread what i wrote.
                      • xxexxundefined
                        xxexx
                        ok, now i deleted all M558 lines and manually retyped "M558 P5 I1", uploaded and restared - no change
                        • xxexxundefined
                          xxexx
                          if i type the same command it works
                          My config.zip includes on "SYS" folder with all the *.g files.
                          Z-Probe
                          M574 Z1 S2 ; Set endstops controlled by probe
                          M558 P5 I1 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                          G31 P500 X100 Y100 Z0 ; Set Z probe trigger value, offset and trigger height
                          M557 X15:15 Y15:315 S20
                          • Vetiundefined
                            Veti
                            that is very strange. what firmware version are you running?
                            also please post your config.zip file
                            • xxexxundefined
                              xxexx
                              M115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.02(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-12-24b1
                              • DocTruckerundefined
                                DocTrucker
                                I see some of these reports have a probe speed of 0 and others 120. That looks odd to me.
                                • xxexxundefined
                                  xxexx
                                  Ok, so now i deleted all files from the SD card and reuploaded all files from the Wiki. -> Sensor was found!
                                  Then i just had to reinsert M558 P5 I1 etc. and it immediately worked.
                                  So it seems that my file structure was wrong and that was the problem.
                                  My distant friend, i would like to thank you for your help and patience - guys like you make the internet great!
                                  BR, Norbert
