Corexy Z offset
@veti said in Corexy Z offset:
G0 Z0
but today I set the BLTouch height more precisely. I did the offset measurement again and got a 0.950 result.
when I move the hotend to the table from the control panel the z axis shows me 0.00
but 0.5mm is still missing to zero -
if you cant get a good result with that. increase the offset and do a first layer test print. increase the z offset until it produces a good enough first layer.
any value I would not enter has no effect on the distance between the nozzle and the table, 0.5mm to zero is still missing
Your M558 contains X0 Y0 Z1.
Why did you put them there?
remove them and try again. -
how are you editing the config.g btw?
I removed it, I did again Z offset 0.951
still on the main panel Z shows 0.00 but the nozzle is 0.5mm above the table -
and if you set the offset to 1.4?
also check under settings, machine properties, that the z offset is actually set.
how can I check under settings, properties, I think I have not done before, what do you mean?
https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
section Machine Properties
Look for trigger height
ok, I seen this, we just use different terms, Trigger Height: 0.7 mm
@chris11 said in Corexy Z offset:
that means your settings are not getting set.
are you restarting the machine after setting the trigger height? -
Yes, I press the emergency button or M999
post your current config.g file again
; generated by RepRapFirmware Configuration Tool v2 on Sat Aug 03 2019 03:22:52 GMT+0100 (Brytyjski czas letni); General preferences
M83 ; ...but relative extruder movesM667 S1 ; Select CoreXY mode
M550 P"My Printer" ; Set machine name
M552 S1 ; Enable network
M587 S"ASUS" P"r2" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Physical drive 0 goes backwards
M569 P1 S0 ; Physical drive 1 goes backwards
M569 P2 S1 ; Physical drive 2 goes forwards
M569 P3 S0 ; Physical drive 3 goes backwards
M92 X80.00 Y80.00 Z4000.00 E420.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X800.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X200 Y200 Z200 S0 ; Set axis maxima; Endstops
M574 X2 Y2 S0 ; X home to min. Y and Z home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min
G31 P25 X0 Y-29.30 Z0.95 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
M557 X5:205 Y5:165 S20 ; Define mesh grid
M558 P5 H5 F500 T4000 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves; Heaters
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T613400 B5025 C1.484206e-7 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; BLTouch - Heaters
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.; Fans
M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0CM501 ; Read parameters from EEPROM
post your config-overwrite.g
; config-override.g file generated in response to M500 at 2019-08-08 21:05
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A548.0 C162.5 D3.6 S1.00 V23.6 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00 -
i dont see where the trigger height of 0.7 is set.
try deleting all G10 commands from the config and overwrite
