Corexy Z offset
@veti said in Corexy Z offset:
M906
ok I am here, welcome back
M906
Motor current (mA) - X:800, Y:800, Z:800, E:800:800, idle factor 30%M906
Motor current (mA) - X:700, Y:700, Z:700, E:700:700, idle factor 30% -
@chris11 said in Corexy Z offset:
G31 P25 X0 Y-29.30 Z0.95
what does the system properties show after you put this command in manually into the console?
Type:
Digital Switch (5)
Trigger Height:
0.7 mm
Trigger Value:
500 -
i am stumped on this. i have no idea why the G31 command would be ignored.
maybe someone else has an idea.
and I times 10 more, I know it's very annoying
which firmware version are you running?
Firmware Version: 2.03 (2019-06-13b2)
WiFi Server Version: 1.23
Web Interface Version: 1.22.6 -
Veti, thank you very much! for your help and time devoted to me.
Maybe someone else has what ideas?? -
ok gentlemen, after 8 hours of searching the internet, and after hundreds of read posts I found a solution to my problem, very trivial reason as usually happens when you can not find any solutions.
I set command in the wrong order here is the explanation:
That can happen if you put the G31 command earlier in config.g than the M558 command. This is because RRF stores different G31 parameters for different types of Z probe, to allow you to use more than one probe. -
the manual G31 should not have been affected by this
from the manual of G31
Tnnn (RepRapFirmware 1.17 and later) Z probe type to which these parameters apply, defaults to the current Z probe type as defined by M558 P parameter
@dc42 is that a bug?
I don't know, but the most important thing is that everything started working fine. Veti thank you again for the time devoted to me, I am very grateful for that!
could anyone help me in setting the heightmap, after auto bed compensation I gets a message that 25 points probed, min error -0.067, max error -0.005, mean -0.042, deviation 0.020 Height map saved to file heightmap.csv,
it means everything is fine, but after printing starts it gets this message:
Error: M375: Height map file bareplate.csv not found -
search all your .g files in the sys folder for that string. also have a look at the gcode you are printing.
hello everyone again, I just came back from Holladay, yesterday I wanted to test my printer and it turned out that it printed mirrored.
I set up my config again, it seems to me correctly but when i homing X-axis moves in the opposite direction. From the Duet main panel all axes work correctly -X goes left and +X goes right. I think I have something wrong set up in homex.g and homeall.g
Can anyone assist in how to set up this properly please
Thanks
here is my configuration:M667 S1 ; Select CoreXY mode
M550 P"My Printer" ; Set machine name
M552 S1 ; Enable network
M587 S"ASUS" P"r ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S1 ; Physical drive 0 goes forwards
M569 P1 S1 ; Physical drive 1 goes forwards
M569 P2 S1 ; Physical drive 2 goes forwards
M569 P3 S0 ; Physical drive 3 goes backwards
M350 Z16 E16 I0 ; Configure microstepping without interpolation
M350 X16 Y16 I1 ; Configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600 E416 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
M906 X900.00 Y900.00 Z1100.00 E900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X200 Y200 Z200 S0 ; Set axis maxima; Endstops
M574 X1 Y2 S0 ; X home to min. Y and Z home to max. Normally Closed limit switches.
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M557 X5:205 Y5:200 S20 ; Define mesh grid
M558 P5 H5 F500 T4000 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
G31 P25 X0 Y-35.40 Z1.20 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment; Heaters
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T613400 B5025 C1.484206e-7 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; BLTouch - Heaters
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duet WiFi board.; Fans
M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0M501
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v2 on Sat Aug 03 2019 03:22:53 GMT+0100
G91 ; relative positioning
G1 S1 X205 Y205 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X205 ; home X axis
G1 S1 Y205 ; home Y axis
G1 X-5 Y-5 F6000 ; go back a few mm
G1 S1 X205 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y205 ; then move slowly to Y axis endstopM98 P"homez.g"
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 S1 X205 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 Z-5 F6000 S2 ; lower Z again
its a matter of swapping the x and y stepper cables or swapping the directions of x or y.
there might be a guide somewhere but i dont know where.
there might be a guide somewhere but i dont know where.hello Veti probably yes, I tried to change the motor connection the other way round, but then all the kinematics change, I just want to change the x axis.
its a combination of those in my above statement i ment to write and instead of or.
If X axis is reversed
switch cables A & B and invert A and B direction -
I changed it as you said, but now the situation is like this, now the head goes in the right direction, stops at the end stop. axis Y the same, but when i homing Z axis, the head stops seeing the X axis end stop and trying to go further in the direction of -X that is mean to the left
