    Duet 2 maestro problems
    2.2k
    • HumanXv2undefined
      HumanXv2
      Ok so it makes no sense but I read the reviews of the cables I got and one guy said he had to swap the green and red wires so i did that and it worked. Now the errors are gone with the motors but now z will not home. I don't have the z stop hooked up since I'm using a bltouch and I have to touch the probe to get the motor to stop.
        A Former User @HumanXv2
        @humanxv2 said in Duet 2 maestro problems:
        Homing is achieved by moving until it hits a endstop, and setting the axis to a known value. The homing is moving until it trips the endstop or probe. So you need to let the motor run until the probe touches the bed, or add a end stop.
        HumanXv2undefined 1 Reply Last reply Reply Quote 0
        • HumanXv2undefined
          HumanXv2 @A Former User
          @bearer said in Duet 2 maestro problems:
          Well the bed is all the back at home so there's it's not there for the probe to touch.
          • HumanXv2undefined
            HumanXv2
            I moved the switch for y so that it's there for the probe to touch
              well move the bed then.
              • HumanXv2undefined
                HumanXv2
                Got everything working. Started a print the other day and I noticed that when it got the the upper layers it was printing in midair and not laying down filament.
                I pulled the nozzle and it was clogged so I unclogged it and put it back on and now the heat is faulting out saying the heat is rising too slow. I switched the motor and heats from e0 to e1 and the heat is still faulting.
                  A Former User
                  Would suggest something changed with respect to wiring or the thermal response in your hotend. Check the wiring and retune the heater.
                  • HumanXv2undefined
                    HumanXv2
                    The heat block was a tad bit loose so I removed the heater cartridge and thermistor to tighten it a little and put them back. I can't tighten it real tight cause the angle the wires end up at, they run into the cooling ducts.
                    The thermistor reads the temp correctly when plugged into e0 but read 2000c when plugged into e1.
                      A Former User
                      and after re-tuning the heater the problem persist?
                      • HumanXv2undefined
                        HumanXv2
                        Auto tune keeps stopping saying the temp is rising too slow. Fans are off and I did M303 H1 P1 and it is still coming up real slow. Either it is coming up fine and the thermistor might be bad and not accurately reading the temp or the heater probe is bad. I switched the probe out earlier and put the stock one back in so I may put the other back in and try.
                        I have already ordered a new thermistor cartridge.
                        • HumanXv2undefined
                          HumanXv2
                          Put cartridge in that came with hot end and it heated fast until 80c then kinda fell on its face.
                          It's back in e0 now. If I put it in e1 do i still use H1?
                          • HumanXv2undefined
                            HumanXv2
                            Heater is in e1 and thermistor is in e1.
                            I changed the config to reflect this and the heater will not come on and the thermistor is showing 2000.
                            Heaters
                            M307 H0 B0 S1.00
                            M305 P0 T98801 B4185 R2200
                            M143 H0 S120
                            M305 P2 T1000000 B4725 C7.06e-8
                            M143 H2 S280
                            • HumanXv2undefined
                              HumanXv2
                              Plugged extruder into e1 and define is as a new tool using e1 gears and so far so good
                              • HumanXv2undefined
                                HumanXv2
                                Still hitting around 80c and slows way down.
                                New heater cartridge on the way.
                                • HumanXv2undefined
                                  HumanXv2
                                  Doing the same thing with new parts. I ordered some external mosfet boards and see if they work.
                                  I ordered a skr 1.3 marlin board I was gonna use and it doesnt like me much.
                                    what does M307 H1output? (or H2 if using E1)
                                    kinda ot but i think alex kenis recently posted a video suggesting there is a design flaw with the usb interface on those?
                                    • HumanXv2undefined
                                      Yeah it stopped communicating with anything.
                                      • HumanXv2undefined
                                        HumanXv2
                                        Still doesnt work. Running through external mosfets it falls on its face around 80c.
                                          dc42 administrators @HumanXv2
                                          @humanxv2, there is absolutely no need to use external MOSFETs with the Maestro, except when driving a bed heater that draws an exceptionally high current.
                                          What happens when the!temperature reaches 80C, and how long does it take to reach that temperature? Please post a copy of the temperature plot from Duet Web Control.
                                          • HumanXv2undefined
                                            HumanXv2
                                            I managed to do an autotune and it worked fine then m500 to save which I didn't do before then set it to heat up and it heated up fine.
                                            I've been installing a linear rail setup on my x axis so I have to wire everything back up and see.
                                            When it was doing it it got to 80c in decent time but I guess it wasnt fast enough for the board and faulted. Hopefully everything is ok now since I really don't wanna resort to using a 22 dollar board.
