Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
Is it ok to have the stepper motors right beside the Duet board, or will I run into some kind of interference?
the pt100 sensor is prone to interference. so keep those wires away from any other wires.
Placing stepper motors close to the Duet shouldn't cause any problem.
Thanks! Now I feel safe to shorten the stepper motor wiring.
The Fisher delta I have is pretty much the same with no problems, though it uses a thermistor rather than PT100:
