    Wifi - Duet becomes invisible
    • 4latheundefined
      4lathe
      This is likely a problem with my router but thought I’d ask anyway. Current problem is on a machine running 3.0 and wifi 1.23 but Ive had it fir awhile on other machines running 2.04 and earlier.
      This morning I turn on the printer. DWC wont connect. I log in to my router. It doesn't show up in the device list. I Screen in through usb. M552 says its connected to my router. I stop and start wifi on the printer with M552 a few times. It says its connected to my router but dies not show in device list. I wait say another 10 minutes and suddenly DWC connects. Still doesn't show in my router’s device list but working fine through DWC. Ping works fine as well.
      When DWC isn't connected, but M552 says it is connected to router, ping returns nothing.
      After waiting 10-15 minutes DWC always ends up connecting but it seems random. This will happen even during printing or idling. It just disconnects and will come back 10-15 minutes later.
      This has been happening for 6 months over different versions of software and on multiple machines and so I figured it was just my router. But there are lots of people smarter than me here so I finally decided to ask.
      8/26/2019, 10:44:03 AM: Connected to 192.168.1.163
      8/26/2019, 11:00:10 AM: M122: === Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.0beta5+2 running on Duet WiFi 1.02 or later
      Board ID: 08DDM-9FAM2-LW4S4-6J9DG-3SJ6S-1MVRZ
      Used output buffers: 3 of 24 (12 max)
      Static ram: 25856
      Dynamic ram: 95376 of which 296 recycled
      Exception stack ram used: 316
      Never used ram: 9228
      Tasks: NETWORK(ready,524) HEAT(blocked,1256) MAIN(running,3744) IDLE(ready,156)
      Owned mutexes:
      Last reset 01:52:25 ago, cause: power up
      Last software reset at 2019-07-27 08:28, reason: User, spinning module GCodes, available RAM 9020 bytes (slot 0)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 38.2, current 38.8, max 39.2
      Supply voltage: min 13.3, current 13.3, max 13.5, under voltage events: 0, over voltage events: 0, power good: yes
      Date/time: 2019-08-26 11:00:08
      Slowest loop: 6.21ms; fastest: 0.07ms
      Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 201.13ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 0, notready 0, noresp 1
        WiFi firmware version 1.23
        WiFi MAC address 5c:cf:7f:76:60:35
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 23880
        WiFi IP address 192.168.1.163
        WiFi signal strength -41dBm, reconnections 0, sleep mode modem
        Your WiFi signal strength is very good, so it isn't a signal strength issue. It may be a router issue, but the other possibility is interference. So try changing the WiFi channel number that your router uses.
        I doubt it's any consolation to you, but currently my Acer tablet disconnects regularly from my Acer router, about once every 5 minutes.
        4latheundefined 1 Reply Last reply Reply Quote 0
        • 4latheundefined
          4lathe @dc42
          @dc42 thx David. Tried that already. Guess its time for a new router!
          • Vetiundefined
            Veti @4lathe
            @4lathe
            what router do you have? you might be able to flash openwrt on your current router.
