RRF3 several issues
Firmware wishlist
    Cecil
    Yesterday I started to modify my machine to RRF3. I found several issues during configuration.
    1.) Heater config
    In wiki are heater outputs listed as inverted, so I activated them through M950 as inverted... Few minutes after booting I started to smell plastic melting - temperature of hotend was according to thermistor >800C! No warning, nothing - even if I have had configured max temp for that heater to 300C. It looks like thermal runaway protection is not working.
    2.) Z homing with probe - I was used to do in RRF2 "G1 Z-215 F720 H1" to quickly go close to bed, after that raise a little bit and do G30. In RRF3 is probe not working as an endstop - or I am not able to configure it. Is it possible to use it in same way like in RRF2, or should I now just use G30 instead and wait for slow probing all the way down if gantry is all the way up?
    Board: Duet Maestro 1.0
    Firmware: RepRapFirmware for Duet 2 Maestro 3.0alpha (2019-08-21b2)
    My config.g and homez.g below 🙂
    ; Configuration file for Duet Maestro (firmware version 1.20 or newer)
    ; generated by RepRapFirmware Configuration Tool on Sun Jun 03 2018 17:10:41 GMT+0200 (Central Europe Daylight Time)
    M550 PMy printer ; Set machine name
    M552 P192.168.1.32 S1 ; Enable network and set IP address
    M553 P255.255.255.0 ; Set netmask
    M554 P192.168.1.1 ; Set gateway
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M584 X0 Y1 Z2:4 E3 U5 V6 ; U=filament chooser mmu, V=filament feeder mmu
    M671 X-40:290 Y0:0 S2 ; leadscews
    M569 P0 S1 ; Drive X goes forwards
    M569 P1 S1 ; Drive Y goes forwards
    M569 P2 S1 ; Drive Z goes forwards
    M569 P3 S0 ; Drive E goes backwards
    M569 P4 S1 ; Drive Z goes forwards
    M569 P5 S0 ; Drive U goes backwards
    M569 P6 S1 ; Drive V goes forwards
    M350 X16 Y16 Z16 E64 U32 V32 I1 ; Microstepping with interpolation
    M92 X100 Y100 Z400 E579.5,579.5,579.5,579.5 U400 V400 ; Set steps per mm
    M566 X300 Y300 Z60 E120 U60 V60 ; Set maximum instantaneous speed changes (mm/min)
    M203 X12000 Y12000 Z720 E7200 U720 V720 ; Set maximum speeds (mm/min)
    M201 X1500 Y1500 Z200 E5000 U200 V200 ; Set accelerations (mm/s^2)
    M204 P1250 T2500 ; Set printing and travel accelerations limit
    M906 X1000 Y1000 Z500 E700 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y-5 Z0 S1 ; Set axis minima
    M208 X250 Y210 Z210 S0 ; Set axis maxima
    M574 X1 S0 P"xstop" ; X endstop low side
    M574 Y1 S0 P"ystop" ; Y endstop low side
    M574 U1 S0 P"e0stop" ; U endstop low side
    M574 Z0 P"nil" ; free Z endstop
    M574 Z1 S2 P"zprobe.in" ; Set endstop controlled by probe
    M558 P1 C"zprobe.in" I1 H0.3 A3 F300 T12000 S0.02 ; Set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X25 Y-2.9 Z1.8 ; Set Z probe trigger value, offset and trigger height
    M557 X30:228 Y5:203 S33 ; Define mesh grid
    ;M305 P0 T100000 B4725 C0 R2200 ; Set thermistor + ADC parameters for heater 0
    M308 S0 P"bedtemp" Y"thermistor" A"Bed temp" T100000 B4725 C0 R2200 ; Set thermistor + ADC parameters for heater 0
    M950 H0 C"bedheat" T0 ; Create bed heater uninverted as heater 0 using thermistor 0
    ;M305 P1 T98130 B4000 R2200 ; Set thermistor + ADC parameters for heater 1
    M308 S1 P"e0temp" Y"thermistor" A"Extruder temp" T98130 B4000 R2200 ; Set thermistor + ADC parameters for heater 1
    M950 H1 C"e0heat" T1 ; Create hotend heater uninverted as heater 1 using thermistor 1
    M143 H1 S300 ; Set temperature limit for heater 1 to 300C
    M106 P0 S0 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S0 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S20.0 R30.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    ; Pressure advance
    M572 D0 S0.15
    ;Extruder ehater PID
    M307 H1 A1049 C299.5 D8.1 B0 S0.5
    ;Bed heater PID
    M307 H0 A119.8 C480.4 D8.5 V23.9 B0
    ;extruder non-linearity
    M592 D0 A-0.004104 B0.003347
    ;initialize display
    M918 P1
    ;filament sensor
    M591 P1 C"zstop" S1
    ;filament sensor at mmu
    M581 P"e1stop" T2 C0
    ;servo at mmu
    M950 S0 C"servo"
    ; homez.g
    ; called to home the Z axis
    G91 ; relative positioning
    G1 Z5 F6000 H2 ; lift Z relative to current position
    G90 ; absolute positioning
    G1 X5 Y7.9 F6000 ; go to first probe point
    ;G1 Z-215 F720 H1 ; move quickly to Z axis endstop and stop there (first pass)
    ;G1 Z2 F720 ; go back a few mm
    ;G90 ; relative positioning
    ;G1 Z2 F900 S2 ; lift Z relative to current position
    undefined undefined 2 Replies Last reply 28 Aug 2019, 11:58 Reply Quote 0
      Cecil
      Today I have made test so I configured it throu console as inverted to see what will happen after going above 300C...
      Heater above 300C
        JoergS5 @Cecil
        This post is deleted!
          dc42 administrators @Cecil
          @cecil said in RRF3 several issues:
          The ! character means invert the usual sense. The additional heater outputs on the expansion connector are active low, so if you were using one of those as GPIO and wanted an active high output, then you would use the ! character to specify inversion in firmware. Thermal runaway protection can't work if the heater is on when the firmware is commanding it it to be off. Is there a particular part of the documentation that you feel misled you into using the ! character?
          It has always been incorrect to treat the Z probe as an endstop. You can use the M558 F parameter to change the probing speed, and thereby do fast-then-slow probing.
          undefined undefined 2 Replies Last reply 28 Aug 2019, 13:54 Reply Quote 0
            gtj0 @dc42
            @dc42 said in RRF3 several issues:
            The example for pin names shows the !. I thought that was odd.
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
            Pin names for Duet 2 WiFi/Ethernet
            Multiple names on a line are aliases for a single pin. An exclamation mark before the pin name
            means that there is inversion between the processor and the corresponding output, and that
            RRF3 will automatically allow for this inversion.
            // Duet 2 and DueX heater outputs
            !bedheat
            !e0heat
            !e1heat
              Cecil @dc42
              In section "Pin names" in wiki post to RRF3 are all pin names listed without explanation mark but heaters are with. I was misled by it. I thought I should use it by default as it is stated in that list.
              Now I know my extruder will survive thermal abuse. Who have extruder which can handle 800C? 😄
              You mean something like changing M558 parameters on the fly during homing? That can work! Thanks
              undefined 1 Reply Last reply 28 Aug 2019, 14:23 Reply Quote 0
                deckingman @Cecil
                Exactly so. For info, this is an extract from one of my homing macros...........
                ;change to faster probing speed
                M558 F450
                G30 ; FAST home Z using values from G31
                G91 ;relative
                G1 Z5 F300 ; lower bed 5mm
                G90 ;absolute
                ;change back to slower probing speed
                M558 F180
                G30 ; SLOW home Z
                2 out of 7
