    Bed Leveling compensates to 1.5~3.5 mm below printing surface
    Smart effector for delta printers
    931
    • worekarolisundefined
      worekarolis @milangupta1
      This post is deleted!
        @milangupta1
        There is G90 in there so no need for G92 as much as I understand
        • Vetiundefined
          Veti
          as milangupta1 said. your bed config should look something like this (adjust for your bed)
          and the M665 and M666 should be in the config.g
          ; bed.g
          ; called to perform automatic delta calibration via G32
          ; generated by RepRapFirmware Configuration Tool v2.0.0 on Thu Aug 29 2019 14:53:59 GMT+0200 (Mitteleuropäische Sommerzeit)
          ; Probe the bed at 12 peripheral and 0 halfway points, and perform 6-factor auto compensation
          ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
          G30 P0 X0 Y84.9 H0 Z-99999
          G30 P1 X42.45 Y73.53 H0 Z-99999
          G30 P2 X73.53 Y42.45 H0 Z-99999
          G30 P3 X84.9 Y0 H0 Z-99999
          G30 P4 X73.53 Y-42.45 H0 Z-99999
          G30 P5 X42.45 Y-73.53 H0 Z-99999
          G30 P6 X0 Y-84.9 H0 Z-99999
          G30 P7 X-42.45 Y-73.53 H0 Z-99999
          G30 P8 X-73.53 Y-42.45 H0 Z-99999
          G30 P9 X-84.9 Y0 H0 Z-99999
          G30 P10 X-73.53 Y42.45 H0 Z-99999
          G30 P11 X-42.45 Y73.53 H0 Z-99999
          G30 P12 X0 Y0 H0 Z-99999 S6
          ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
          ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
          worekarolisundefined 1 Reply Last reply Reply Quote 0
            worekarolis @Veti
            @veti
            sorry, I've labeled this incorrectly. M665 and M666 are in the config overide. Correcting post.
            • Vetiundefined
              Veti
              are you using mesh bed compensation?
              i.e. loading the heightmap somewhere
              worekarolisundefined 2 Replies Last reply Reply Quote 0
                worekarolis @Veti
                @veti
                I've used it, but now its disabled.
                  worekarolis @Veti
                  @veti
                  coud this be a problem?
                  G29 S1 ; load a previously-generated height map
                  • Vetiundefined
                    Veti @worekarolis
                    @worekarolis
                    yes. loading it will change the z=0 based on the values in the heightmap.
                      worekarolis @Veti
                      @veti
                      Removing it haven't changed behavior
                      • fcwiltundefined
                        fcwilt
                        The trigger height setting for your Z-probe might be wrong.
                        The H parameter to M665 might be wrong.
                        Either one can result in Z=0 not being the surface of the bed.
                          worekarolis
                          After updating to 2.04RC1 (2019-07-14b1) issue is gone.
                          Many thanks for your help!
