BLTouch probe acting funny
Ok so my build is coming along nicely and i've got all the homing figured out. However, whenever i go to do the auto bed compensation via the web interface, the z axis moves down, and the probe deploys without enough room. this causes the probe to hit the aluminum bed and fail to trigger. BUT when i do a regular homing routine, all is good. what did i goof up?
; generated by RepRapFirmware Configuration Tool v2.0.0 on Sat Aug 31 2019 17:45:57 GMT-0400 (Eastern Daylight Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X300 Y300 Z400 S0 ; Set axis maxima
; automatic saving on power loss is not configured; Drives
M569 P3 S0 ; physical drive 3 goes Backwards
M350 Z16 I0 ; configure microstepping without interpolation
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M203 X12000.00 Y12000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z60.00 E3000.00 ; set accelerations (mm/s^2)
M84 S30 ; Set idle timeout
M566 X1200 Y1200 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y30000 Z600 E3000 ; Set maximum speeds (mm/min); Axis Limits
M208 X340 Y375 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; set active high endstops
M574 Z1 S3 ; set endstops controlled by motor stall detection; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H1 F500 T10000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X10 Y10 Z1.46 ; set Z probe trigger value, offset and trigger height
M557 X15:280 Y30:350 S50 ; define mesh grid; Heaters
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; Filament Sensing
M591 D0 P1 C3 S1; Custom settings are not defined
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v2.0.0 on Thu Aug 29 2019 20:39:55 GMT-0400 (Eastern Daylight Time)
M280 P3 S10 I1 -
@skivvy said in BLTouch probe acting funny:
M558 P9 H1
Your dive height (H1) is only 1mm, which isn't enough room for the pin to deploy. Change it to 10 for starters and maybe reduce it to 5 if you think you can safely get away with it.
