    G30 won't go far enough to reach probe
    1.1k
    • Nightreaverundefined
      Nightreaver
      That happens to me once in a while. For homeall and homez is replaced all G30 with G30 Z-99999
      I think that fixes it.
      • RedWagonundefined
        RedWagon
        Sorry, I commented out the default ones but the probe is defined earlier with:
        M558 P4 I1
        I've tried several combinations of the suggestions above but they all do the same thing.
        G20
        G30 Z-99999
        G30 Z-200
        M208 Z200
        G30
        G30 Z-99999
        G30 Z-200
        M208 S1 Z-200
        G30
        G30 Z-9999
        M208 Z0:200
        G30
        G30 Z-999999
        M208 Z-200:200sG30 Z-9999
        G30
        G30 Z-99999
        I measured and it dives for 10mm then returns to its original height.
        From reading the docs it doesn't really sound like I should be doing a large dive for G30. Do I need to run G28 first with the endstop assigned to Z probe?
          Does your Z axis move the correct amount? For example, if you send G91 followed by G1 S2 Z50 does it move the print head up or the bed down 50mm?
          • RedWagonundefined
            RedWagon
            It's off by a little bit; right now it's travelling 8mm per 10mm. Shouldn't be enough for it to run through the max axis settings and not trigger the probe. I tested by doing a G92 Z0 then moving it around manually.
              dc42 administrators @RedWagon
              @redwagon said in G30 won't go far enough to reach probe:
              It sounds to me that either your Z steps/mm is a little off, or your Z speed or acceleration is set too high. I suggest you find out which:
              • Calculate the Z steps/mm from the pitch/lead of your leadscrew mor the belt pitch and number of pulley teeth
              • If you think you have set the correct Z steps/mm, try reducing Z speed and/or acceleration in M203 and M201
              When you have the Z movement sorted, try plain G30 with no parameters.
              • RedWagonundefined
                RedWagon
                I've adjusted the Z steps/mm and lowered speed and acceleration. No changes; G30 by itself still lowers 10mm and throws the "Z probe was not triggered during probing move" error.
                • RedWagonundefined
                  RedWagon
                  config.g
                  M555 P2						; Set output to look like Marlin
                  G21						; Work in millimetres
                  G90						; Send absolute coordinates...
                  M83						; ...but relative extruder moves
                  ; No bed heater
                  M140 H-1
                  ; Disable Fan 1 thermostatic mode
                  M106 P1 H-1
                  ; Axis and motor configuration
                  M569 P0 S0					; Drive 0 goes forwards
                  M569 P1 S1					; Drive 1 goes forwards
                  M569 P2 S0					; Drive 2 goes forwards
                  M569 P3 S1					; Drive 3 goes forwards
                  M558 P4 I1					; use E0 endstop as Z probe
                  M574 X1 S2					; bind X homing switch to Z probe
                  M574 Y0						; radius homing switch present, no turntable homing switch
                  M669 K7 R0:150 H0.3 F30 A30 			; set Polar kinematics parameters
                  M666 X0 Y0 Z0					; put your endstop adjustments here, or let auto calibration find them
                  M350 X16 Y16 Z16 E16:16 I1			; Set 16x microstepping with interpolation
                  M92 X80 Y80 Z3200			 	; Set axis steps/mm
                  M906 X1000 Y1000 Z1000 E800 I60			; Set motor currents (mA) and increase idle current to 60%
                  M201 X1000 Y1000 Z100 E1000			; Accelerations (mm/s^2)
                  M203 X6000 Y6000 Z100 E3600 			; maximum linear speeds mm/minute
                  M566 X1200 Y1200 Z1200 E1200			; Maximum instant speed changes mm/minute
                  ; Thermistors
                  M305 P1 T100000 B3974 R4700 H30 L0		; Put your own H and/or L values here to set first nozzle thermistor ADC correction
                  M570 S180					; Hot end may be a little slow to heat up so allow it 180 seconds
                  M106 P1 S-1					; disable thermostatic mode for fan 1
                  ; Tool definitions
                  M563 P0 D0 H1					; Define tool 0
                  G10 P0 S0 R0					; Set tool 0 operating and standby temperatures
                  M92 E80:80					; Set extruder steps per mm
                  ;*** If you are using axis compensation, put the figures in the following command
                  M556 S78 X0 Y0 Z0				; Axis compensation here
                  M208 Z-0.2:200					; set axis travel limits
                  T0						; select first hot end
                  homeall.g
                  ; Home All
                  G91 ; relative movement
                  G1 Z4 F100 H1; ensure head is clear of the bed
                  G1 S1 X-200 F3000 ; move radius towards minimum until the endstop switch is triggered
                  G1 S2 X5 ; move radius out by 5mm
                  G1 S1 X-20 F600 H1; move radius slowly to the endstop switch again
                  ; Home Bed
                  G90 ; absolute movement
                  G1 S2 X10 ; move to 10mm from centre of bed
                  G92 X10 Y0 ; define current position as X10 Y0
                  ; Home Z
                  ; G1 X0 Y0 ; put head over the centre of the bed, or wherever you want to probe
                  G30 ; lower head, stop when probe triggered and set Z to trigger height
                  homebed.g
                  G1 Z4 F100 H1 ; ensure head is clear of the bed
                  G1 S2 X0 ; move to centre of bed
                  G92 X0 Y0 ; define current position as X0 Y0
                  G1 Z-4 F100 H1; restore original Z position
                  homedelta.g
                  ; Example Homing file for RepRapFirmware on delta printer
                  ;M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
                  ;G91							; use relative positioning
                  ;******* Change F250 in the following line to F2500 when you are finished commissioning
                  ;******* Change 320 in the following to a higher value if your Kossel has taller towers
                  ;G1 S1 X320 Y320 Z320 F2500	; move all carriages up 320mm, stopping at the endstops
                  ;G1 S2 X-3 Y-3 Z-3			; move all carriages down 3mm
                  ;G1 S1 X6 Y6 Z6 F250			; move carriages slowly up 6mm, stopping at the endstops
                  ;G1 Z-5 F2000				; down a few mm so that we can centre the head
                  ;G90							; back to absolute positioning
                  ;G1 X0 Y0 F2000				; centre the head and set a reasonable feed rate
                  homeradius.g
                  G1 S1 X-20 F600 ; move radius slowly to the endstop switch again
                  homez.g
                  G1 Z4 F200 H1; raise head 4mm to ensure it is above the Z probe trigger height
                  G90 ; back to absolute mode
                  ;G1 X0 Y0 ; put head over the centre of the bed, or wherever you want to probe
                    Have you tested the Z probe? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                    • RedWagonundefined
                      RedWagon
                      I ran through those tests and still get the same results. I have to manually move the printer within 5mm of the Z probe triggering or it will give the error "Z probe was not triggered during probing move"
                      • RedWagonundefined
                        RedWagon
                        Finally fixed it!
                        The missing command was setting the Z endstop to the Z probe with M574 Z1 S2
