    Trobuble after firmware 2.03 (2019-06-13b2)
    Firmware installation
    449
      Can you post your config.g please?
      TPJensenundefined 1 Reply Last reply Reply Quote 0
      • TPJensenundefined
        TPJensen @Phaedrux
        @phaedrux said in Trobuble after firmware 2.03 (2019-06-13b2):
        ; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
        ; Delta Settings
        M665 L440.000 R227 H456.0 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
        M552 S1
        M550 P"Anycubic Predator" ; Set machine name
        M551 P"" ; Set password
        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M569 P3 S0 ; Drive 3 goes forwards
        M92 X80.00 Y80.00 Z80.00 E380.45 ; Set steps per mm
        M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
        M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
        M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
        M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        ; Retraction
        M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Set active high endstops
        M558 P4 H3 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
        G31 P500 X0 Y0 Z16.0 ; Set Z probe trigger value, offset and trigger height
        M557 R115 S20 ; Define mesh grid
        G29 S1 ; Load the heightmap
        M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
        M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
        M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M143 H1 S250 ; Set temperature limit for heater 1 to 240C
        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 H1 ; Define tool 0
        M572 D0 S0.1 ; Pressure Advance
        ;M591 D0 P2 C4 S1 ; Activate filament sensor
        M404 N1.75 ; Set for print monitor
        M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0
        M501 ; Load saved parameters from non-volatile memory
          It looks like you do not have a T0 command at the end of your config.g. You would need to have one in the slicer start gcode or at the end of config.g (or both) to ensure that a tool is selected/enabled before a print is started.
          From your screen shot though, it looks like the tool was heated, so there must be a T0 in your slicer code, or you manually enabled it. In which case, there may be a heater fault causing the heater to turn off. Do you see any heater fault error messages in the gcode console?
          Have you done a PID tune on your heater? Are you sure you have the correct thermistor values for your thermistor?
          As an aside, you may want to use Firmware version 2.04RC1 due to some bug fixes for delta printers.
          TPJensenundefined 1 Reply Last reply Reply Quote 1
          • TPJensenundefined
            TPJensen @Phaedrux
            @phaedrux
            Yes I-am sure it works because with the old firmware I did alot of prints with no problems.
            here is my start g-code from my slicer there is T0
            M104 S[extruder0_temperature] T0 ; heat nozzle
            M190 S[bed0_temperature] T0 ; heat bed and wait
            M109 S[extruder0_temperature] T0 ; wait for nozzle
            G28 ; home all
            G1 X-50 Y-180.0 Z5 F4000.0 ; go to the outer front edge
            G1 Z0.3 ; lower nozzle to purge height
            G92 E0 ; reset the extruder
            G1 X0.0 E9.0 F1000.0 ; purge nozzle
            G1 X50.0 E12.5 F1000.0 ; purge nozzle
            • Vetiundefined
              Veti @TPJensen
              @tpjensen
              T0 has to be its own command. not part of the M104 or M190 or M109
              • TPJensenundefined
                TPJensen @Veti
                @veti said in Trobuble after firmware 2.03 (2019-06-13b2):
                @tpjensen
                Okay I did not know that...
                Okay can you maybe help my and rewrite my start gcode so it works ?
                And maybe if I have to put in the config.g file where and what to write
                • Vetiundefined
                  Veti
                  put this at the end of your config.g
                  T0 ; select first tool
                  • TPJensenundefined
                    TPJensen @Veti
                    hehe okay it that all ?? ☺
                      You can add a T0 to the start of your slicer gcode as well to catch the cases where the tool may have been disabled at some point between power on and starting a print.
                      • Vetiundefined
                        Veti
                        yes it is.
                        see
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_T_Select_Tool
                        • TPJensenundefined
                          TPJensen @Veti
                          @veti
                          Okay that was easy then 😎
