    Firmware upgrade from 1.15b fails
    Firmware installation
    1.4k
      Also when doing such a huge jump in versions (and for any update really) it's a good idea to give the update release notes a read through to catch any of the major changes that require config changes.
        This may come in handy as well.
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        • frontrangeundefined
          frontrange
          I followed the direction to reload (Recovery #3) up to a point and got USB back up.
          Now here's the problem from the web page (Recovery #1):
          "Also copy file iap4e.bin (for Duet WiFi/Ethernet) or iap4s.bin (for Duet Maestro) into /sys
          If your board is a Duet WiFi, also copy the new DuetWiFiServer.bin file into /sys"
          Any idea where I might find these two files because they are not on the 2.04RC1 files area on github.
            If you're on 1.18.1 check the 1.19 release. This iep files aren't included with every release, only when they change, so you'll have to check through the releases to find.
            The major releases to check would be 1.19, 1.21, and 2.0
              frontrange
              I got this far, but still no wifi:
              M115
              FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-04-09
              ok
              M997 S1
              Trying to connect at 460800 baud: success
              Erasing 290848 bytes...
              Uploading file...
              5% complete
              10% complete
              15% complete
              20% complete
              25% complete
              30% complete
              35% complete
              40% complete
              45% complete
              50% complete
              55% complete
              60% complete
              65% complete
              70% complete
              75% complete
              80% complete
              85% complete
              90% complete
              95% complete
              Upload successful
              ok
                frontrange
                Where do I find this please:
                M997 S2
                File DuetWebControl.bin not found
                ok
                  @frontrange said in Firmware upgrade from 1.15b fails:
                  M997 S2
                  ok
                  Are you currently on 1.18.1?
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
                  S2 - web server file system, filename sys/DuetWebControl.bin (needed only when using RepRapFirmware 1.18 series and earlier for Duet 2 WiFi)
                  After 1.18 it stopped being a .bin file and became a separate zip file which unpacked to a /www folder that hosted the files for DWC.
                  You can get the webcontrol bins from here: https://github.com/dc42/RepRapFirmware/releases?after=v1.19
                  Though you'll need to rename them to DuetWenControl.bin because the file names include the version number.
                  You're getting close. Trust me, once you get to 2.0 and reconnected to the DWC the update process becomes far far easier.
                    frontrange
                    I do not understand what you are telling me to do. I am on Duet WiFi FIRMWARE_VERSION: 1.18.1 ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-0
                    I need some actual direction here, if I'm supposed to pick and chose files between different releases, or files are misnamed or whatever I need actual directions that can be followed without bricking this thing again, that is assuming I can resist the urge to crush it with a sledgehammer.
                      So I don't think you really need the webcontrol bin at all at this point since you're aim isn't to continue to use 1.18 you want to upgrade past it.
                      So you have 1.18 installed you should be able to follow the procedure here for going from 1.18 to 1.19
                      https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19
                        A Former User @frontrange
                        I can 100% guarantee you that you will only brick something once... and just to calm the FUD you don't brick a Duet through firmware upgrades, as it can be recovered by USB unless physically broken.
                        That out of the way, there is no point in going through every incremental release, but you really should read the whatsnew section for every release. Then get the full 2.03 stable release which has the complete archive. Now you should be able to update to the 2.04RC1 binary if you need any of the features from that, if not stick with the stable 2.03.
                          frontrange
                          Now what?? Right back to where I started, just stuck at a slightly later release:
                          M997 S2
                          Erasing 3125248 bytes...
                          Uploading file...
                          5% complete
                          10% complete
                          15% complete
                          20% complete
                          25% complete
                          30% complete
                          35% complete
                          40% complete
                          45% complete
                          50% complete
                          55% complete
                          60% complete
                          65% complete
                          70% complete
                          75% complete
                          80% complete
                          85% complete
                          90% complete
                          95% complete
                          Upload successful
                          ok
                          M115
                          ok
                            I suggest you upgrade to 2.03 using this procedure https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_2_WiFi.
                              frontrange
                              After spending however many hours trying to do what I would have thought was a simple firmware upgrade I've come to the end of my rope with this thing.
                              I followed every set of directions to the letter. I went on a scavenger hunt for the latest needed files spread across multiple releases because nothing is properly organized so you can just do a single download and roll. And I have now got the latest code installed on a controller that will not start the wifi.
                              These directions are crap. Some of the missing steps I could figure out, like they start by telling you to disable the wifi in config, and never tell you to go back and remove the comment, or they tell you to just plug in the sd card and send the upgrade command, but make no mention that the card isn't reread till you power cycle so files will not be found.
                              What other steps are missing? I'm too old to keep torturing myself with trying to get this haphazard collection of ideas to work.
                              Thanks anyway...
                                Are you able to connect to the Duet from your PC using YAT or another terminal emulation program? If so, what version does it report when you send M115?
                                  frontrange
                                  Told you I'm done, its in the trash where it belongs. Thanks anyway.
                                    If that's how you feel, I'll mark this as solved so that nobody else who want to help wastes any more time looking at it.
                                      frontrange
                                      Whatever floats your boat.
                                        dc42 administrators @frontrange
                                        I forgot to mention, you have the option of asking for help again and setting it back to unsolved if you change your mind.
                                          frontrange
                                          After walking away from this for a bit it occurred to me that following those directions may have wiped my network configuration out without happening to mention that tidbit.
                                          Sure enough, that was the last problem. I wouldn't ever recommend this process to anyone else, leave it be or buy a new one. I wasted a full day on this.
                                            Thanks for pointing this out. Yes, upgrading from pre-1.19 to 1.19 or later firmware requires you to re-enter the WiFi access point details. I'll add this to those instructions.
