    Replace the Wifi or Ethernet module by the ESP-13?
    1.5k
    • Kanyoundefined
      Kanyo
      This post is deleted!
      • Kanyoundefined
        Kanyo @A Former User
        @bearer
        I'm prepared to change the wiring or make some sort of breakout board, but whether need to edit the firmware or do some program thing?
        The module used must be certified by TELEC (MIC). As far as I know the only EXP8266 module that has passed this certification in Japan is ESP-WROOM-02. (https://www.espressif.com/sites/default/files/esp-wroom-02_telec_certificate.pdf)
        The manufacturer of ESP-WROOM-02 is Espressif Inc, and the ESP-13 seems to be AI-thinker. There seems to be no difference in function, footprint, and pin assignment.
          A Former User
          You can upload the DuetWifiServer firmware to the SD card and flash it from the serial(usb) console, so thats not a problem if 2MB flash is enough. I've only previously seen dc42 reccomending using ESP-07S for external antenna, and that is the 4MB version of ESP-07 but not sure if 4MB is a requirement.
            A Former User
            dc42 said in swapping out ESP module for ethernet module:
            imrj said in swapping out ESP module for ethernet module:
            dc42 ok dc...yea i got one of those too with an external antenna....i can swap it out but do i need to worry about flashing anything into the ESP07S?
            You will need to copy DuetWiFiServer.bin into /sys on the SD card if it isn't already there. Then send M997 S1 from USB or PanelDue to install it on the new module.
            Make sure it is the ESP-07S that you have. The older ESP-07 won't work.
            Kanyoundefined 1 Reply Last reply Reply Quote 0
            • Kanyoundefined
              @bearer
              The original ESP8266 wifiserver doesn't seem to work well with 2MB flash..
              (https://github.com/dc42/DuetWiFiServer >> https://reprap.org/forum/read.php?2,582444,582444#msg-582444)
              and ESP-07 has only 1MB flash, but ESP-07S seems to have 4MB
              ESP-WROOM-02 with 2MB flash may not be good idea 😞
              At least,it looks physically possible without magical smoke or some thing, thanks to the powerful onboard flash of the reprap firmware.
              thanks for infomation.
                A Former User
                Yeah, flash size was the primary concern.
                You could perhaps get the Ethernet version and use a Raspberry Pi as a wireless bridge now, and at some point you could be able to remove the Ethernet and connect the Pi to the Duet 2 Ethernet in the same way as the Duet 3 if/when such a firmware is made for the Duet 2.
                (Asuming you can use the Raspberry Pi or similar single board computer)
                • Danalundefined
                  Danal
                  I wouldn't mess with the board. I'd get an ethernet Duet, and plug a Japan certified device with a cable a few centimeters long. There are a ton of devices out there specifically designed for the task of making an Ether client look like a Wireless client.
                  You do NOT want a Bridge or AP... it is Ok if it has those "modes"... you want a device that is (or set to the mode of) being a client.
                  • Kanyoundefined
                    @bearer
                    Wow Duet 3? You say remove the ethernet module and connect the Pi to duet board directly?
                      A Former User @Kanyo
                      @Kanyo said in Replace the Wifi or Ethernet module by the ESP-13?:
                      ref this thread and this reply from dc42 https://forum.duet3d.com/post/106138
                      • Kanyoundefined
                        Kanyo @Danal
                        @Danal
                        before posting here I was thinking about plug a Wifi Bridge.
                        A device acting as a client may different from a bridge or AP,I have never seen such a thing
                        For example, what kind products can be used?
                          A Former User
                          Technically it should be both a wifi client and then a bridge between the wifi client and the ethernet port, which is how it would be done with a board like a Raspberry pi.
                          Kanyoundefined 1 Reply Last reply Reply Quote 1
                          • Kanyoundefined
                            Yeah I know, such like WRH-583BK2-S
                            or as you said RPi can bridge between the wifi client and the ethernet port, right?
                            I just wondering what kind of network device can just being the client Instead of connected ethernet ,not bridge or AP.
                              A Former User
                              Admittedly I haven't tried it with the RPi since way back when Wifi was a USB stick, and being able to run as an actual bridged connection may depend on the WiFi chipset in use; but in any case it should be possible to do a routed connection and forward the necessary ports.
                              (I'll see if I can find time later this week to borrow the Duet 3's RPi 3B and try bridging it to the Duet 2 Maestro, but busy week)
                                @bearer said in Replace the Wifi or Ethernet module by the ESP-13?:
                                Originally the web pages were held in flash memory on the ESP module, which is why there was a DuetWiFiServer.bin file and you needed 4Mb flash memory. Now that the web page files are served from SD card, even 1Mb ought to be enough. But I've never tried uploading DuetWiFiServer to a module with less than 4Mb of flash.
                                The reason we specify the ESP-07S not the ESP-07 is that only the S version has been FCC certified.
                                The WROOM module is slightly wider than the ESP-12S. We looked at it a while back before the ESP-07S became available, and we concluded that it didn't quite fit in the space available.
                                • Danalundefined
                                  Danal
                                  Probably my odd phrasing.
                                  It is quite fair to say that what you need is a device acting as both a client and a bridge to the Ether. My real point was: Not an AP.
                                  And... WRH-583BK2-S is an example of what you DON'T want. This device 'expects' internet on an Ether port, and routes it to a WiFi segment where this device is the AP for that segment. That is the "wrong direction" for what you are trying to accomplish.
                                  • Danalundefined
                                    Danal
                                    And... to my best reading of a translation of the user manual for the WRH-583BK2-S, it looks like it actually WILL do what you need.
                                    See "child machine mode" on page 47 of the full manual here
                                    • Kanyoundefined
                                      Kanyo @dc42
                                      @dc42 So that's it.
                                      Thanks for the great effort, may be try to make a breakout board someday.
                                      I feel sad that WROOM module was not chosen, no help for a larger footprint.
                                      The big reason I want to replace a Wifi module is mDNS protocol.
                                      Are there any plans to implement the mDNS protocol on the Duet2Ethernet?
                                      Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                      • Kanyoundefined
                                        Kanyo @Danal
                                        @Danal
                                        Sorry for the confusion on the Japanese page, thanks for looking seriously.
                                        May be this picture is a good explanation of what this device can do.
                                        • Danalundefined
                                          Danal @Kanyo
                                          @Danal
                                          Yep, looks like it WILL do it. Nifty little gadget.
                                          • Danalundefined
                                            Danal @Kanyo
                                            That's a pretty good reason to make the "WiFi Client to Ether" box a Raspberry Pi. Setting it up as the client/bridge is straightforward (tons of examples) and mDNS is also relatively easy. Being *nix literate at the command line is helpful, but not essential, due to the many examples.
