    Replace the Wifi or Ethernet module by the ESP-13?
    1.6k
      A Former User
      Admittedly I haven't tried it with the RPi since way back when Wifi was a USB stick, and being able to run as an actual bridged connection may depend on the WiFi chipset in use; but in any case it should be possible to do a routed connection and forward the necessary ports.
      (I'll see if I can find time later this week to borrow the Duet 3's RPi 3B and try bridging it to the Duet 2 Maestro, but busy week)
        @bearer said in Replace the Wifi or Ethernet module by the ESP-13?:
        You can upload the DuetWifiServer firmware to the SD card and flash it from the serial(usb) console, so thats not a problem if 2MB flash is enough. I've only previously seen dc42 reccomending using ESP-07S for external antenna, and that is the 4MB version of ESP-07 but not sure if 4MB is a requirement.
        Originally the web pages were held in flash memory on the ESP module, which is why there was a DuetWiFiServer.bin file and you needed 4Mb flash memory. Now that the web page files are served from SD card, even 1Mb ought to be enough. But I've never tried uploading DuetWiFiServer to a module with less than 4Mb of flash.
        The reason we specify the ESP-07S not the ESP-07 is that only the S version has been FCC certified.
        The WROOM module is slightly wider than the ESP-12S. We looked at it a while back before the ESP-07S became available, and we concluded that it didn't quite fit in the space available.
        Kanyoundefined 1 Reply Last reply Reply Quote 1
        • Danalundefined
          Danal
          Probably my odd phrasing.
          It is quite fair to say that what you need is a device acting as both a client and a bridge to the Ether. My real point was: Not an AP.
          And... WRH-583BK2-S is an example of what you DON'T want. This device 'expects' internet on an Ether port, and routes it to a WiFi segment where this device is the AP for that segment. That is the "wrong direction" for what you are trying to accomplish.
          • Danalundefined
            Danal
            And... to my best reading of a translation of the user manual for the WRH-583BK2-S, it looks like it actually WILL do what you need.
            See "child machine mode" on page 47 of the full manual here
            Kanyoundefined 1 Reply Last reply Reply Quote 0
            • Kanyoundefined
              Kanyo @dc42
              @dc42 So that's it.
              Thanks for the great effort, may be try to make a breakout board someday.
              I feel sad that WROOM module was not chosen, no help for a larger footprint.
              The big reason I want to replace a Wifi module is mDNS protocol.
              Are there any plans to implement the mDNS protocol on the Duet2Ethernet?
              Danalundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • Kanyoundefined
                Kanyo @Danal
                @Danal
                Sorry for the confusion on the Japanese page, thanks for looking seriously.
                May be this picture is a good explanation of what this device can do.
                • Danalundefined
                  Danal @Kanyo
                  @Kanyo said in Replace the Wifi or Ethernet module by the ESP-13?:
                  @Danal
                  Yep, looks like it WILL do it. Nifty little gadget.
                  • Danalundefined
                    Danal @Kanyo
                    That's a pretty good reason to make the "WiFi Client to Ether" box a Raspberry Pi. Setting it up as the client/bridge is straightforward (tons of examples) and mDNS is also relatively easy. Being *nix literate at the command line is helpful, but not essential, due to the many examples.
                      dc42 administrators @Kanyo
                      When we designed the Duet WiFi, there was only one WROOM module and no external antenna option; whereas there were several ESP modules, some of which were certified. Since that time there have been two new WROOM modules, both certified, one with external antenna. To change to it would have required moving the SD card slot, which would have been incompatible with existing enclosure designs, and would in turn have required moving the mounting point for the Ethernet daughter board - so a new version of the daughter board would have been needed.
                      Yes.
                      • Kanyoundefined
                        Kanyo
                        I expect so much.
                          A Former User @A Former User
                          @Kanyo FYI this works with my RPi 3B+ https://willhaley.com/blog/raspberry-pi-wifi-ethernet-bridge/
                          I tested Option 1 and it works just fine with my Duet 2 Maestro. The Pi gets an IP address of its own so you can still administrate it from the same network. The Duet 2 Maestro even gets the same (non reserved) DHCP lease through the bridge and mDNS works with the older firmware, but the Pi could probably be made to announce on the Duet's behalf if needed.
                          Edit: I'll add the whole thing here, with warnings and all; in case the link dies in the future..
                          Note: This script drastically changes the networking configuration and your Pi may end up in an unreliable networking state if anything goes wrong
                          #!/usr/bin/env bash
                          set -e
                          [ $EUID -ne 0 ] && echo "run as root" >&2 && exit 1
                          # Update these variables as needed
                          ssid="the ssid"
                          psk="the password"
                          country="US"
                          # You should not need to update anything below this line
                          apt update && apt install parprouted dhcp-helper
                          systemctl stop dhcp-helper
                          systemctl enable dhcp-helper
                          systemctl mask networking.service
                          systemctl mask dhcpcd.service
                          if [ -d /etc/network/interfaces ];
                          then
                            mv /etc/network/interfaces /etc/network/interfaces.bak
                          fi
                          sed -i '1i resolvconf=NO' /etc/resolvconf.conf
                          systemctl enable systemd-networkd.service
                          systemctl enable systemd-resolved.service
                          ln -sf /run/systemd/resolve/resolv.conf /etc/resolv.conf
                          cat > /etc/wpa_supplicant/wpa_supplicant-wlan0.conf <<EOF
                          ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
                          update_config=1
                          country=${country}
                          network={
                              ssid="${ssid}"
                              psk="${psk}"
                          EOF
                          chmod 600 /etc/wpa_supplicant/wpa_supplicant-wlan0.conf
                          systemctl disable wpa_supplicant.service
                          systemctl enable wpa_supplicant@wlan0.service
                          cat > /etc/systemd/network/08-wlan0.network <<EOF
                          [Match]
                          Name=wlan0
                          [Network]
                          DHCP=yes
                          IPForward=yes
                          EOF
                          cat > /etc/default/dhcp-helper <<EOF
                          DHCPHELPER_OPTS="-b wlan0"
                          EOF
                          cat <<'EOF' >/etc/avahi/avahi-daemon.conf
                          [server]
                          use-ipv4=yes
                          use-ipv6=yes
                          ratelimit-interval-usec=1000000
                          ratelimit-burst=1000
                          [wide-area]
                          enable-wide-area=yes
                          [publish]
                          publish-hinfo=no
                          publish-workstation=no
                          [reflector]
                          enable-reflector=yes
                          [rlimits]
                          EOF
                          cat <<'EOF' >/etc/systemd/system/parprouted.service
                          [Unit]
                          Description=proxy arp routing service
                          Documentation=https://raspberrypi.stackexchange.com/q/88954/79866
                          [Service]
                          Type=forking
                          # Restart until wlan0 gained carrier
                          Restart=on-failure
                          RestartSec=5
                          TimeoutStartSec=30
                          ExecStartPre=/lib/systemd/systemd-networkd-wait-online --interface=wlan0 --timeout=6 --quiet
                          ExecStartPre=/bin/echo 'systemd-networkd-wait-online: wlan0 is online'
                          # clone the dhcp-allocated IP to eth0 so dhcp-helper will relay for the correct subnet
                          ExecStartPre=/bin/bash -c '/sbin/ip addr add $(/sbin/ip -4 -br addr show wlan0 | /bin/grep -Po "\\d+\\.\\d+\\.\\d+\\.\\d+")/32 dev eth0'
                          ExecStartPre=/sbin/ip link set dev eth0 up
                          ExecStartPre=/sbin/ip link set wlan0 promisc on
                          ExecStart=-/usr/sbin/parprouted eth0 wlan0
                          ExecStopPost=/sbin/ip link set wlan0 promisc off
                          ExecStopPost=/sbin/ip link set dev eth0 down
                          ExecStopPost=/bin/bash -c '/sbin/ip addr del $(/sbin/ip -4 -br addr show eth0 | /bin/grep -Po "\\d+\\.\\d+\\.\\d+\\.\\d+")/32 dev eth0'
                          [Install]
                          WantedBy=wpa_supplicant@wlan0.service
                          EOF
                          systemctl daemon-reload
                          systemctl enable parprouted.service
                          systemctl start wpa_supplicant@wlan0 dhcp-helper systemd-networkd systemd-resolved
                          Edit 2: Pay attention to the country="US" variable to ensure local compliance with Wifi channels/frequencies
