    Cannot connect to DWC Simple fix??
    Duet Web Control
    2.0k
    • Danalundefined
      Danal
      If M587 can potentially be misleading; under many circumstances, it shows the network memorized when the board was tested at the factory.
      Enter M552 with no parameters. What does that say? Can you Web to that address? Can you ping that address?
      • AMPMAKERundefined
        AMPMAKER
        I entered M552 and received the same IP address. Did not find it when entered
        in the the browser.
        M552
        WiFi module is connected to access point ORBI, IP address 192.xxx.x.xx<LF>ok<LF>
        • Danalundefined
          Danal
          Can you ping it?
          • AMPMAKERundefined
            AMPMAKER
            No, it will not ping.
            • AMPMAKERundefined
              AMPMAKER
              Let me rephrase that.
              It came back with "Packets sent 4, Received =0, Lost =4 (100% loss)
              Danalundefined 1 Reply Last reply Reply Quote 1
              • fcwiltundefined
                fcwilt @AMPMAKER
                @AMPMAKER said in Cannot connect to DWC Simple fix??:
                M552
                And is that the name of your access point?
                • Danalundefined
                  Danal @AMPMAKER
                  Yep, that equals "will not". 🙂
                  You are not giving up security information to put the actual IP addresses on this forum. For example, one of my Duets is at 192.168.1.15. And I can ping it (see below)
                  What is the actual IP of your printer? And of your PC?
                  Pinging my printer:
                  Pinging 192.168.1.15 with 32 bytes of data:
                  Reply from 192.168.1.15: bytes=32 time=2ms TTL=255
                  Reply from 192.168.1.15: bytes=32 time=184ms TTL=255
                  Reply from 192.168.1.15: bytes=32 time=9ms TTL=255
                  Ping statistics for 192.168.1.15:
                      Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
                  Approximate round trip times in milli-seconds:
                      Minimum = 2ms, Maximum = 184ms, Average = 49ms
                  My windows machine's ip configuration:
                  C:\Users\Danal>ipconfig
                  Windows IP Configuration
                  Ethernet adapter Ethernet:
                     Media State . . . . . . . . . . . : Media disconnected
                     Connection-specific DNS Suffix  . :
                  Ethernet adapter Ethernet 2:
                  Wireless LAN adapter Local Area Connection* 12:
                  Wireless LAN adapter Local Area Connection* 13:
                  Wireless LAN adapter Wi-Fi:
                     Link-local IPv6 Address . . . . . : fe80::9d90:e77f:bdf1:4625%19
                     IPv4 Address. . . . . . . . . . . : 192.168.1.9
                     Subnet Mask . . . . . . . . . . . : 255.255.255.0
                     Default Gateway . . . . . . . . . : 192.168.1.1
                  • AMPMAKERundefined
                    AMPMAKER
                    Yes Orbi is the name of the router. Orbi is a tri band router and this may be an issue. From what I have read
                    it has the ability to pick up 2.4 or 5 ghz independently. But this does not look like that is happening.
                    I have looked at other forums to see a way around this, but it gets way more into changes I don't want
                    to explore.
                    192.168.1.31 Duet IP
                    And with the Duet wifi only working with 2.4 I may be out of luck. As we need the Orbi right now to get the
                    signal farther for everyone to have a good signal.
                    Can the Duet be setup and used without the wifi.? For now I need to get our printer back up. This has consumed
                    way to much of my time and will use it or will need to replace.
                    fcwiltundefined Adrian52undefined 2 Replies Last reply Reply Quote 0
                    • EasyTargetundefined
                      EasyTarget
                      Yes it can, I have done just this in the past. It got me through a crisis.
                      It's a lot of fiddling; constantly removing the SD card to edit config files or add gcode files.
                      • Use the terminal to test and refine the correct syntax for config file commands; generate heater tunings etc..
                      • You will then need to be popping the SD card out and in to upload gcode files, and make any permanent changes to the config files,
                      • Use M23 etc to select and print.
                      • Conceptually; the web interface does it's magic by sending gcode commands to RRF behind-the-scenes, and allowing direct uploading files to SD. In theory there is nothing you can command in the web interface that cannot also be sent via the terminal.
                      Another 'get me working' option would be to use a mobile phone or similar to make a hotspot for just the printer and run the UI from the phone, or a laptop on the same hotspot.
                      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                      PrintPy2024 to the rescue!
                      MicroPython based; with simple wiring and and no custom PCB.
                      • Danalundefined
                        Danal
                        • The printer can be an AP. Totally separate from your network. That does mean you have to switch to it... but probably less hassle than physically manipulating the SD card.
                        • Does Orbi not route between the 2.4 and 5 segments? Yikes!! That's a real problem. And, with great respect, are you sure this is the problem? I've run both Linksys mesh routers and Google WiFi mesh routers, and also Netgear "single central" routers with two Duet WiFi. No issues with printer on 2.4 and PC on 5.
                        • fcwiltundefined
                          fcwilt @AMPMAKER
                          Unless something is wrong with the router configuration, or perhaps the router itself, devices connected via the LAN connection(s) on the router, via 2.4 GHz or 5.0 GHz should all be able to communicate with one another.
                          All of the access points in my home are dual band (2.4 & 5) and I have no issues like you are having. I can connect to my two Duet Wifi equipped machines without any problems.
                          Don't give up.
                          • AMPMAKERundefined
                            AMPMAKER
                            No I am not sure the router is the issue, But...
                            I asked someone who is more knowledgeable than me, that's said the Orbi is a mesh network
                            and most likely the issue. In hind sight it would have been easier to wire an Ethernet cable.
                            Easy Target. Our issue with removing the card, over time, is our screen will be put on the right side
                            of the printer, and access to the card is the left. So it would need to have separate containment for
                            the Panel-Duet. We are using cards to transfer the files now, which is fine, but all the conf.. that's
                            a lot of back and forth.
                            • Danalundefined
                              Danal
                              Yeah, Orbi should be fine with 2.4 and 5 devices talking to each other. And "mesh" is NOT the issue, otherwise nothing in your house would work...
                              You can certainly test this. Find any other device on the 2.4 network (I don't have an orbi, so you'll have to look up how to do this) and ping it.
                              • Adrian52undefined
                                Adrian52 @AMPMAKER
                                @AMPMAKER I have been using an orbi router with my duet WiFi. So not a complete no no. Just fixed the address that was assigned to the duet, no other fiddling.
                                AMPMAKERundefined 1 Reply Last reply Reply Quote 0
                                • fcwiltundefined
                                  fcwilt @AMPMAKER
                                  If it IS a mesh setup that still would not explain the problem.
                                  There is often a setting in the WiFi portion of a router configuration which allows enabling "client isolation".
                                  When this is enabled wireless devices (WiFi) cannot communicate with wired devices.
                                  That sounds like it might be the case.
                                  • AMPMAKERundefined
                                    AMPMAKER @Adrian52
                                    @Adrian52
                                    Ok, Just fix the address? What exactly do you mean?
                                    my IP shows 192.168.1.31 on the Duet when I enter M552
                                    see below. But when I try to Ping I get no response.
                                    m552
                                    WiFi module is connected to access point ORBI, IP address 192.168.1.31<LF>ok<LF>
                                    The Blue light flashed for a bit and entered M552 again and got a different IP.
                                    m552
                                    WiFi module is changing mode<LF>ok<LF>WiFi module is connected to access point ORBI, IP address 192.168.1.4<LF>
                                    Now it is connected.... Wow very frustrating but all I did.. I Think.. is turned off the ORBI (cycled Power)
                                    while the Duet was plugged into and powered by the USB cable.
                                    Now I enter 192.168.1.4 and the Duet screen comes up.
                                    Thank you all for the suggestions and help. Would have been a long time trying to figure this out without help.
                                    Issue solved..
                                    • AMPMAKERundefined
                                      AMPMAKER
                                      Will the Duet remember the IP address? Or do I need to send another M command?
                                      • AMPMAKERundefined
                                        AMPMAKER
                                        Got it M552 S1 is already in the Network config.g file.
                                        • fcwiltundefined
                                          fcwilt @AMPMAKER
                                          You can specify a static IP Address for the Duet WiFi in the M587 command which is NOT meant to always be present in your config.g file.
                                          It's fine to put it there just to get the correct values stored in the WiFi module but once everything is working you need to comment out or remove the M587 command from your config.g.
                                          Now the only problem with using a static IP address is that the router may try to handout that same address to another device that is asking for an IP address from the router.
                                          You can avoid this problem by limiting the range of addressed the router can handout. This is a setting in the router configuration.
                                          For example you could configure the router to handout IP address from x.x.x.21 to x.x.x.254, leaving addresses 2 through 20 for assignment to hardware like your Duet.
                                          • AMPMAKERundefined
                                            AMPMAKER
                                            This is not my strongest area to be working in, so it is very frustrating when I get it to
                                            work and now it doesn't. I unplugged the duet from the USB ate lunch came back to reconnect
                                            and back to square one. Now no YAT. Saying com5 is closed, and no wifi of course.
                                            Device manager see's it plugged into com 5??? What am I missing.
                                            I do understand handing out IP address above a certain range, but shouldn't the device always
                                            have the same IP, once it is set.
