    X axis position
    • Rudy2Aundefined
      Rudy2A
      Hello, I am having a problem with the position of my X axis.
      By default in my Config.g file, it is at -23. Because of this, I can not place the center of my bed and encounter X positions in error.
      and when I do a Home, all my settings are 0 except the X.
      If I make a G92 X0, then M500, it's ok or there is something else to do thank you.
      • Vetiundefined
        Veti
        the minimum position is defined by the
        M208
        command in the config.g
        Rudy2Aundefined 1 Reply Last reply Reply Quote 0
        • Rudy2Aundefined
          Rudy2A @Veti
          @Veti said in X axis position:
          a position minimum est définie par la
          commande
          M208 dans config.g
          thank you,
          If I put a 0 in place of a -23 in; (config.g) Axis Limits
          M208 X-23 Y0 Z0 S1
          When I do a leveling of my bed, I have a band in my height map (Heightmap.csv) that is not taken into account. That's why I was advised to put -23 in place of 0?
          • fcwiltundefined
            fcwilt
            If you home in the max direction whatever value is set as max for that axis becomes the position after homing.
            Likewise if you home in the min direction whatever value is set as min for that axis becomes the position after homing.
            When you do G92 X0 you are telling the machine that the current position, which the min value says is -23, is actually 0. I don't think you want to be doing that. If the physical position is actually X=0 then the min value should be 0.
            Assuming the min value of -23 is correct then to obtain X=0 after homing you need to put a G1 X0 command into your homeX.g file.
            • Rudy2Aundefined
              Rudy2A
              Thank you all ...
              Problem solved .
                Also, M500 doesn't work like that. It's not the same as the 8-bit firmware EEPROM save.
                With reprap it saves a specific set of values to config-override.g, usually things that are computed by the firmware or measured in an automatic way.
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
