    Change the Router Duet WiFi don't work (ok but....)
    • samu_87undefined
      samu_87
      Hi i had read some documentation about this.
      I know perfectly that changing the SSID and WPA duet can't connect to the network, so I describe what I had do:
      Disable 5ghz WiFi on router, after that i remove SD card and replace M587 in the config file with the new SSID and WPA but after i read that isn't the right way to do that, so:
      I connect Duet with the Terminal (Mac OS) with USB cable, I turned off the wifi with M552 S-1, after turn on WiFi M552 S0 i put new M587 with only new SSID and WPA after that i put the command M552 S1. But still not working.
      I try to wait 10 minute to wait that Duet enter in access point mode but can't go.
      What can I do? Maybe i make something wrong or not in the right order.
      Many thanks!
      • cts5191undefined
        cts5191
        I had to remove the space in my SSID name for it to work and make it all caps, since I was using proterface.
        samu_87undefined 1 Reply Last reply Reply Quote 0
        • samu_87undefined
          samu_87
          This post is deleted!
          • samu_87undefined
            samu_87 @cts5191
            @cts5191 Thanks but my SSID name don't have any space and all caps... Thanks...
            • Shaunundefined
              Shaun
              I had the same issue, change your wifi security so that you force only WPA2 PSK, dont use mixed mode. You can then use 2 and 5G without any issues.
              samu_87undefined 2 Replies Last reply Reply Quote 1
              • samu_87undefined
                samu_87 @Shaun
                @Shaun OH many thanks I'll give it a try!
                • samu_87undefined
                  samu_87 @Shaun
                  @Shaun You find the problem, I had disable mixed mode and now work fine!!!
                  Many Thanks cheers!
