    Calibrate Z probe trigger height
    • hmortensenundefined
      hmortensen
      Hi
      I've got an Ender 3 pro with Duet2Wifi and BlTouch v3.1 sensor.
      Everything else is stock.
      FW: 2.03 (2019-06-13b2)
      I've followed this guide:
      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
      But when I issue "G30 S-1" repeatedly, the height increases with every probing.
      Config for probe:
      M574 Z1 S2
      M307 H3 A-1 C-1 D-1
      M558 P9 H5 F500 T4000
      G31 P500 X-43 Y-6 Z2.845
      M557 X10:200 Y10:200 S20
      Result of 10 probings (last is first):
      Stopped at height 2.932 mm
      Stopped at height 2.922 mm
      Stopped at height 2.920 mm
      Stopped at height 2.912 mm
      Stopped at height 2.908 mm
      Stopped at height 2.900 mm
      Stopped at height 2.895 mm
      Stopped at height 2.890 mm
      Stopped at height 2.882 mm
      Any ideas to solve this?
      • Vetiundefined
        Veti
        this would suggest a mechanical issue.
        is the mount for the bltouch stable and has no play?
        • EasyTargetundefined
          EasyTarget
          As @Veti says.. it looks remarkably like something is not properly tightened and moving slightly with each probe. I've been there, it's confusing. But as far as I know there is no way of mis-configuring the Duet which could cause this, so look to hardware.
          Another option is the Z axis maybe hitting it's limit at the very last moment and dropping a step or two just as the probe is triggering.. that would push your height off too.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
            Phaedrux Moderator @hmortensen
            @hmortensen said in Calibrate Z probe trigger height:
            M558 F500
            Reduce your feed rate by 1/5th to F100
            G31 P500
            Reduce your trigger threshold to P25
            You're probing too fast and with too little sensitivity
              hmortensen
              Hi
              Thanks for your inputs.
              I've concluded that my Z axis is offbeat.
                @hmortensen can you elaborate?
