Turn laser only on?
Laser Cutters
492
    pauledd
    Hi
    I made great progress in wiring and connecting my test-laser to the duet
    board as described in this tutorial and now I want to calibrate the laser focus.
    As the laser is normaly controlled via G1 X.. Y.. S.... commands, how can I simply turn on the laser at a specific pwm value to adjust the focus point without movement in the X/Y axis?
    ----- human being without Windows™ ------
      dragonn
      Try M4 S255 or M4 S1
      undefined 1 Reply Last reply 2 Oct 2019, 11:12 Reply Quote 0
        pauledd @dragonn
        @dragonn said in Turn laser only on?:
        Error: M4 command is not supported in machine mode Laser
          EasyTarget
          I think; until some upcoming changes hit release, you need to disable laser mode while finding focus since any movement will kill the laser. This is by design, a good safety feature, but irritating when focusing or size checking.
          I would create a macro for this that disables laser mode and sets the laser power to your focusing setting in one go. Dont forget a 'end' macro (Or M291/292 to confirm ending) to make things safe again afterwards.
          Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
          PrintPy2024 to the rescue!
          MicroPython based; with simple wiring and and no custom PCB.
          undefined 1 Reply Last reply 2 Oct 2019, 13:14 Reply Quote 1
            pauledd @EasyTarget
            @EasyTarget said in Turn laser only on?:
            you need to disable laser mode while ...
            Ok so I disable Laser mode by enabling another mode, I assume CNC because thats the only mode that works with M4 command...
            So I do a "M453 P3 R255" to enable CNC mode on Heater3 with PWM max to 255. If I then issue a "M4 S10" nothing happens. The laser stays off...
            undefined 1 Reply Last reply 2 Oct 2019, 13:48 Reply Quote 0
              EasyTarget @pauledd
              @pauledd said in Turn laser only on?:
              Using the default CNC mode is what I intended, yes.
              Sounds like an improvement over getting an error.
              What happens if you do the same with M3?
              • M4 (reverse) has little application in for lasers.
              • It is used by some other firmwares to enable specific power modulation modes etc.
              undefined 1 Reply Last reply 2 Oct 2019, 14:43 Reply Quote 1
                pauledd @EasyTarget
                Works! ☺
                Can now turn ON/OFF the Laser with M3 S255, M3 S0
                undefined 1 Reply Last reply 2 Oct 2019, 14:58 Reply Quote 1
                  EasyTarget @pauledd
                  Works!
                  Great!,
                  I just realised that M453 P3 R255:255 would also solve this by enabling M4; it's the 2nd option on the R parameter that does that.
                  But.. I've also found with CNC's that the important thing is to come up with a workflow that works, and not get too fussy about the details, that way lies madness.
                  2 out of 8
