Turn laser only on?
Hi
I made great progress in wiring and connecting my test-laser to the duet
board as described in this tutorial and now I want to calibrate the laser focus.
As the laser is normaly controlled via G1 X.. Y.. S.... commands, how can I simply turn on the laser at a specific pwm value to adjust the focus point without movement in the X/Y axis? -
Try M4 S255 or M4 S1
@dragonn said in Turn laser only on?:
Error: M4 command is not supported in machine mode Laser -
I think; until some upcoming changes hit release, you need to disable laser mode while finding focus since any movement will kill the laser. This is by design, a good safety feature, but irritating when focusing or size checking.
I would create a macro for this that disables laser mode and sets the laser power to your focusing setting in one go. Dont forget a 'end' macro (Or M291/292 to confirm ending) to make things safe again afterwards.
@EasyTarget said in Turn laser only on?:
you need to disable laser mode while ...
Ok so I disable Laser mode by enabling another mode, I assume CNC because thats the only mode that works with M4 command...
So I do a "M453 P3 R255" to enable CNC mode on Heater3 with PWM max to 255. If I then issue a "M4 S10" nothing happens. The laser stays off...
@pauledd said in Turn laser only on?:
Using the default CNC mode is what I intended, yes.If I then issue a "M4 S10" nothing happens
Sounds like an improvement over getting an error.
What happens if you do the same with M3?- M4 (reverse) has little application in for lasers.
- It is used by some other firmwares to enable specific power modulation modes etc.
Works!
Can now turn ON/OFF the Laser with M3 S255, M3 S0
Thanks. -
Works!
Great!,
I just realised thatM453 P3 R255:255
would also solve this by enablingM4
; it's the 2nd option on the R parameter that does that.
But.. I've also found with CNC's that the important thing is to come up with a workflow that works, and not get too fussy about the details, that way lies madness.
