    Having problems with Anycubic Kossel Linear Plus calibration
    calibration
    7.6k
    • SnakeSPundefined
      SnakeSP @infiniteloop
      @infiniteloop
      The mesh is dense (305 points).
      As for the delamination reasons - looks like the nozzle is a bit too low at that points. Babystepping +0.05 solved this, but this again is not permanent solution...
      • infiniteloopundefined
        infiniteloop @SnakeSP
        @SnakeSP
        The mesh is dense
        Too lazy to do the math, but the resolution is at approx. 10 mm - not enough for a close look. But talking about babystepping: Do I understand you right that this is only true for prints in these two areas, or does this work for the whole print bed?
        SnakeSPundefined 1 Reply Last reply Reply Quote 0
        • SnakeSPundefined
          @infiniteloop
          Babystepping +0.05 works for the whole print. At least it did not make the other parts being printed worse.
            @SnakeSP
            Then, you simply subtract 0.05 (mm) from your Z probe height - which is exactly the same as to set the babystepping to +0.05. It might be worth trying some even finer adjustment by subtracting one or two more hundredths. Good luck!
            SnakeSPundefined 2 Replies Last reply Reply Quote 0
            • SnakeSPundefined
              @infiniteloop
              Did that before and after autocalibration with new Z probe height (correct direction - subtracted 0.05, double-checked that) and creating new bed mesh ended with printing mid air... Which is strange.
              • SnakeSPundefined
                @infiniteloop
                Did just as you've suggested (Z probe height - 0.05) and surprisingly it did work (i have not changed heightmap.csv this time).
                Print comes out with almost acceptable quality:
                The only thing that bothers me is that defects at the start of each print:
                photo2 photo3 photo4
                it happens after retraction and moving to new coordinates, so i suspect this is due to incorrect retract settings in slicer.
                For now i use (bowden tube 640 mm with ID 2 mm):
                Retraction distance = 8.0 mm
                Extra restart distance = 0.4 mm
                Retraction vertical lift = 1 mm
                Retraction speed = 100 mm/s
                Coasting distance = 0,25 mm (was not able to make Pressure Advance work yet).
                Z vertical speed = 40 mm/s, movement speed = 200 mm/s
                  @SnakeSP Ah, spaghetti printing! Maybe you should switch to some eatable filament?
                    @SnakeSP
                    First things first: Congrats! One problem solved. What happens when you create a new height map remains to be seen, that’s the next step.
                    Your photos look familiar to me, I’m in the middle of the same fight with my own printer (just a mean cartesian, bowden setup). So, I can’t provide a solution yet, only two observations:
                    Print results became better when I reduced the retraction distance (currently at 6 mm).
                    Your retraction speed looks way too high - I don’t dare to go beyond 30 mm/s.
                    And yes, pressure advance is a hot topic in the forum, I just try to learn about that from the wise guys over here…
                    • SnakeSPundefined
                      @infiniteloop 🙂
                        @SnakeSP Sorry for that…
                        • SnakeSPundefined
                          @infiniteloop
                          As for retraction speed - i tried low speeds (30-40 mm/s) and got way too much stringing. But will try to lower down for experiments.
                          Distance - yes, looks too much, will lower it.
                            @SnakeSP
                            …got way too much stringing
                            With PETG, in my case it helped to lower the hot end temperature a bit (-5 deg.).
                            • SnakeSPundefined
                              @infiniteloop Yes, lower temperature reduces stringing, but i'm already at 240 С for the first layer and 220 C for all higher layers. 220 C is the lowest temperature recommended by my filament manufacturer.
                              So looks the only 3 parameters i can play to reduce stringing are Retraction length, retraction speed and coast at end.
                                @SnakeSP
                                My PETG is rated at 210-220 C. Worked for my Aero clone the printer came with, but when I mounted an original E3D water-cooled design, I had to go with 235-240 C instead. Everything is relative…
                                • Vetiundefined
                                  Veti
                                  @SnakeSP said in Having problems with Anycubic Kossel Linear Plus calibration:
                                  you might want to build flying extruder.
                                  • SnakeSPundefined
                                    SnakeSP @Veti
                                    @Veti That's interesting, but not in nearest future as it is rather complicated.
                                    • Danalundefined
                                      Danal
                                      I have a printer with about 1.1meter bowden. I run 4 to 5 mm retract at 40.
                                      • SnakeSPundefined
                                        SnakeSP @Danal
                                        @Danal On what plastic? I use PETG now and it is very prone to stringing. What extruder are you using? I'm on stock Anycubic one, which is not very accurate. Extruder modification is next thing to upgrade in my list after making magnetic arms.
                                          dc42 administrators @SnakeSP
                                          Measured Z offset at all points from bed.g with G30 S-1 and updated bed.g with H for each point
                                          If you mean that you just used G30 S-1 to see what Z value it was triggering at, that is NOT what the G30 H parameter is for. It is for correcting for variations in trigger height at different points, if your Z probe doesn't have a consistent trigger height. See https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Adding_trigger_height_corrections_to_the_bed_g_file.
                                          • SnakeSPundefined
                                            SnakeSP @dc42
                                            @dc42 I'm a bit confused.
                                            Let's say i'm measuring Z probe height initially at X0 Y0. I go through the steps 1-9 described in https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer section "Measuring the trigger height". I read, let's say, 15.500 at that point. Repeating the steps 7-9 several times show that trigger height is consistent at X0 Y0. I put this value to config.g an do autocalibration.
                                            After calibration i check the trigger height value at X0 Y0 and get consistent result 15.500.
                                            But when i move, let's say, to X50 Y0 and do G30 S-1 i get 15.550. I repeat G30 S-1 several times at this point and always get 15.550. So this is consistent.
                                            I thought that i should add this +0.05 value to G30 in the bed.g file for the corresponding point. Am i wrong?
