    CNC: Tool Offsets, Coordinate Systems, Confusion
    CNC
    2.5k
      T3P3Tony administrators
      @vwegert have you read this:
      https://duet3d.dozuki.com/Wiki/Gcode#Section_G54_to_G59_3_Select_coordinate_system
      I know its not much information but points to the L parameter in G10:
      https://duet3d.dozuki.com/Wiki/Gcode#Section_G10_Set_workplace_coordinate_offset_or_tool_offset
      If Workspace co-ordinates work the same way as tool offsets the DWC display updates to show the co-ordinates of the system that is in use.
      I don't have a CNC machine myself so I hope @Danal, @Ryan-Lock or one of the other CNC experts can chip in.
      • Danalundefined
        Danal
        I've seen the thread and will do my best to write a comment later today (Texas, so US central time).
        Meanwhile, a couple of quick thoughts:
        • DWC (should) always display the CURRENT 'work' coordinate system. Unless you change it, this will be G54.
        • This is an important concept: A given machine is ALWAYS in a work coordinate system. It my be true that the current work coordinate system does (or does not) exactly match machine coordinates... and this causes a lot of people who've never used work systems before to think "I've always operated in machine coordinates in the past"... but that's not really true. You've always operated in G54 which had 0,0,0 offset vs. machine.
        • If you do use G53 (machine coord) in a G-Code command line, remember it is NOT MODAL. That is, it applies only to the line on which it appears.
          Thanks @Danal!
          • Ryan Lockundefined
            Ryan Lock
            Hey, as above DWC only displays work coordinates of the system you are currently in. That homing position is the same as what we use on our CNC Machines. I am currently making an alternative web control for CNC Machines which puts all the buttons needed to hand and allows easy switching between work coordinates. You can download the beta at: https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
            T3P3Tonyundefined 1 Reply Last reply Reply Quote 2
              T3P3Tony administrators @Ryan Lock
              @Ryan-Lock that looks interesting, will you be hosting the project on Github as a fork of DWC?
                Ryan Lock
                Yup you can find it here: https://github.com/lockryan/DuetWebControl
                  I suggested to chrishamm long ago that DWC needs an option to display both machine and work coordinates. But I am guessing that your fork goes beyond that.
                  • vwegertundefined
                    vwegert
                    Thanks everyone - I've managed to run a few simple test cuts after using my "cheapishaw" probe, and I'll try a more complex part tomorrow. So far it's looking very promising.
                    EasyTargetundefined 1 Reply Last reply Reply Quote 0
                    • EasyTargetundefined
                      EasyTarget @vwegert
                      @vwegert Good luck!
                      @Ryan-Lock ditto!
                      Workspace switching and handling sounds great, having been batch-making PCB's via a web interface without it i can comfortably call it a killer feature 😉 I got heartily sick of having to switch to the console to swap co-ordinate systems. Adding macro buttons helped, but made the UI look diseased.
                      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                      PrintPy2024 to the rescue!
                      MicroPython based; with simple wiring and and no custom PCB.
                      Ryan Lockundefined 1 Reply Last reply Reply Quote 0
                        Ryan Lock @EasyTarget
                        @EasyTarget Yeah we have found for users doing production manufacturing they require easy use of all work coordinates. After the release of this version, the next thing i am going to add is the ability to apply custom names to the systems, instead of just numbers.
                        • Danalundefined
                          Danal
                          This sounds very intriguing. Are there some screenshots anywhere of it up and running on a CNC?
                            Ryan Lock @Danal
                            @Danal I haven't got any to hand right now, but will make some 🙂
                            • Danalundefined
                              Danal
                              Take a quick look at the work coordinate selector built into ChiliPeppr.:
                              http://chilipeppr.com/tinyg
                              When not connected to a controller board, it WILL show the coordinate selector, it will not show the axis DROs for work and machine.
                              I like the coordinate selector. Play with the + and - buttons, click on a level and see it highlight, etc. Source for it is here: http://github.com/chilipeppr/widget-wcs Javascript/HTML5, so easy to grab chunks and reuse them in browser based apps.
                              Actually, I like the DRO style display as well, but I will need to be connected to a board to show you a screen shot.
                                Ryan Lock
                                Thanks for the info, their system is pretty nice! I like their graphics to see which layer you are on.
                                Mine is simply just a drop down list which allows you to select which one. On one of the settings page i am hoping to add a panel where you can see the work zero for each system in machine coordinates, edit them, and give each system a custom name, which will then show in the drop down instead of the number.
                                • Danalundefined
                                  Danal
                                  Nice screenshot.
                                  One suggestion: Make Work v Machine visually different. Larger/smaller, different colors, etc. It is fairly standard to make Work larger/bolder/brighter.
                                    Ryan Lock
                                    Thanks for the suggestion i will see what i can do.
                                      EasyTarget
                                      IF we are making suggestions here; this is mine. I do a lot of manual jogging when making PCB's etc. The ESP3D derived jog control panel on my esp32 based controllers webUI is excellent; heartily recommended, very intuitive to use.
                                      The blue buttons at the right are Macros, the little buttons beside the machine position are for zeroing individual or all axes. Per-axis homing is also supported and has proved handy on occasions.
                                      Not shown is how each concentric ring is a different amount; and a clear animation hilights exactly what you are about to click on, and what it does.
                                      This is slightly out of date; the latest version shows machine as well as workspace position, I like having the macro editor right there in the panel too.
                                      I just switched to using this after using the jog controls in LaserWeb a lot; those are similar layout to the Duet WebUI, easier to mis-click, I do have some foundation for preferring the bullseye approach.
                                        @EasyTarget Thanks for the suggestions, i will take them all on board. I have had a few other people prefer the bullseye approach to jogging as well. I have stuck with the current Duet Web Control jogging in our control to speed up production. But definitely something for the future. I have also got a lot of request for keyboard jogging.
                                          EasyTarget @Ryan Lock
                                          @Ryan-Lock said in CNC: Tool Offsets, Coordinate Systems, Confusion:
                                          Listen to those requests! It's something on my wish-list too.
                                            @EasyTarget Haha i will figure it out ☺
