Solved G29 S1 when no heightmap is present causes startup failure
If you try to load a heightmap at the end of config.g and there isn't one yet, the DCS thows the following error and the Duet3 fails to start.
err] Code G29 S1; Load and activate heightmap caused an exception: System.IO.FileNotFoundException: Could not find file '/opt/dsf/sd/sys/heightmap.csv'. ile name: '/opt/dsf/sd/sys/heightmap.csv' at Interop.ThrowExceptionForIoErrno(ErrorInfo errorInfo, String path, Boolean isDirectory, Func`2 errorRewriter) at Microsoft.Win32.SafeHandles.SafeFileHandle.Open(String path, OpenFlags flags, Int32 mode) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) at DuetAPI.Utility.Heightmap.Load(String filename) in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetAPI/Utility/Heightmap.cs:line 72 at DuetControlServer.Codes.GCodes.Process(Code code) in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Codes/GCodes.cs:line 65 at DuetControlServer.Commands.Code.ProcessInternally() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 323 at DuetControlServer.Commands.Code.Process() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 269 at DuetControlServer.Commands.Code.Execute() in /usr/src/3d/dc42/workspace/DuetSoftwareFramework/src/DuetControlServer/Commands/Code.cs:line 204 ``
You don't need to load the heightmap until you are ready to print.
That doesn't happy until you have homed and set the "Z=0 Datum".
After those are done then you can load the heightmap. Assuming you have created one.
So remove that command from your config.g file
Yeah my point was that it used to be silently ignored and now throws an exception and prevents the Duet from starting.
@gtj0 said in G29 S1 when no heightmap is present causes startup failure:
I see.
But if you don't have that G29 (which you shouldn't) all is good - correct?
@fcwilt said in G29 S1 when no heightmap is present causes startup failure:
I see.
Kinda... You get:
Height map loaded from file /opt/dsf/sd/sys/heightmap.csv Error: Command SimpleCode has reported an error: [FileNotFoundException] Could not find file '/opt/dsf/sd/sys/heightmap.csv'.
which should be handled better.
Again, I'm trying to flush out as many RRF3/DSF bugs as I can so that when the first production run of the Duet3 starts rolling out those users will have a better experience.
You said in the past the error was "silent".
Perhaps it is better if folks know something went wrong.
@chrishamm I updated pull request https://github.com/chrishamm/DuetSoftwareFramework/pull/68 to catch IOException and print an error message instead of letting the exception bubble up. Done for
G29 S1
,G29 S3
,M374
andM375
.G29 S1 Error: Could not find file '/opt/dsf/sd/sys/heightmap.csv'.
