    RepRapFirmware 2.04RC3 now available
    Beta Firmware
    9
    23
    2.1k
      dc42 administrators @avaradus
      @avaradus said in RepRapFirmware 2.04RC3 now available:
      @dc42 Problem with overflow buffers in longer prints is still there.
      Used output buffers: 24 of 24 (24 max)
      And connection with printer loss and freeze.
      I suspect this is related to using multiple clients on different IP addresses to access the web interface. Is that what you are doing? Are the clients instances of Duet Web Control, or something else?
      avaradusundefined Adrian52undefined 2 Replies Last reply Reply Quote 0
      • avaradusundefined
        avaradus @dc42
        @dc42 no, i have one computer and one ip address
        boldnutsundefined dc42undefined 2 Replies Last reply Reply Quote 0
        • boldnutsundefined
          boldnuts @avaradus
          @avaradus How long do you have to be printing for this issue to show up, I have been doing 3/4 day print's and not seen it?
          avaradusundefined 1 Reply Last reply Reply Quote 0
            Do you use any plugins to upload code from slicers to the Duet over the network?
            • appjawsundefined
              appjaws
              Printed a number of items after upgrading to 2.04RC3 and have not detected any problems whatsoever.
              Great job, thanks for all of the development.
              appjaws - Core XYUV Duet Ethernet Duex5
              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
              Ormerod 1-converted to laser engraver, Duet wifi
              OpenSCAD version 2024.03.18
              Simplify3D 5.1.2
              • Christophe76350undefined
                Christophe76350 @boldnuts
                @boldnuts said in RepRapFirmware 2.04RC3 now available:
                I am using pins 1 "5 volts", pin 2 "gnd" and pin 8 "heater 3" on the expansion header and z probe header gnd and z_probe_in.
                It's also intermittently deploying and retracting again, I have again rolled back to RC2 and can confirm that this issue goes away with this version.
                Same configuration, same problem for me back in 2.03 no problem.
                • avaradusundefined
                  avaradus @dc42
                  @dc42 i'm use gcode generated from Kisslicer 1.5 and upload it to printer with browser Google Chrome without any plugins.
                  Now i have 2 printers with Duet.
                  First printer with Duet 0.6 working stable without any bugs and problems.
                  RepRapFirmware for Duet version 1.19 running on Duet 0.6
                  Used output buffers: 2 of 32 (32 max)
                  Second printer with Duet wifi
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC3 running on Duet WiFi 1.02 or later
                  Used output buffers: 5 of 24 (20 max)
                  There memory leak and used buffers increases and increases and later printer lost connection.
                  I think need remember what changes have occurred with the firmware in the functions of working with buffers? if you compare versions 1.19 and 2.04 ?
                  • avaradusundefined
                    avaradus @boldnuts
                    @boldnuts Somtimes it happens in one day many times! And sometime nothing happins for a week ! This is some random bug.
                    • Adrian52undefined
                      Adrian52 @dc42
                      @dc42 I have still got this issue with 2.04rc3 too, using WiFi upload from dwc 2.02 /Firefox /win 10. No other computer accessing the duet. Usually lose connection after 2-4 hrs printing - print continues to completion. Can usually connect via yat, but incomplete M122 response. Resets with m999 via yat.
                        dc42 administrators @Adrian52
                        @Adrian52 said in RepRapFirmware 2.04RC3 now available:
                        I have a possible fix for this, which will be included in 2.04RC4. But I can't be sure it works, because I cannot reproduce the problem.
                        Adrian52undefined 1 Reply Last reply Reply Quote 0
                        • Adrian52undefined
                          Adrian52 @dc42
                          @dc42 thank you very much - looking forward to testing it.
                          • mihaitinteaundefined
                            mihaitintea
                            Hi
                            Sorry to ask a n00b question. I have 2.04RC1 and I do not clearly understand what files to download from https://github.com/dc42/RepRapFirmware/releases/tag/2.04RC3 and how to upload them.
                            Best regards
                            Mihai
                            piperswundefined 1 Reply Last reply Reply Quote 0
                            • piperswundefined
                              pipersw @mihaitintea
                              @mihaitintea For Duet2 board : Duet2CombinedFirmware.bin
                              For maestro :DuetMaestroFirmware.bin
