24V air/vacuum pump questions pertaining to inrush current
the diode is there to protect against back EMF and not surge. AFAIR the fame mosfets are actually recommended not to exceed 1.5 amps.
@Dougal1957 Sorry i probably didn't word my previous question clearly. I mean to put two diodes in parallel to prevent back EMF. May be overkill?
So if the Fan mosfets are actually recommended to not exceed 1.5 amps, does that mean the minimum resistance for the thermistor should be:
24v / 1.5 = 16 Ohm?
Perhaps this thermistor would be suitable?
Actually I have another thought for the thermistors.
Could I use 5 of 100 ohm thermistors in parallel?
This should theoretically bring the resistance down to 20 ohm. 20ohm should reduce the maximum current down to 1.2 amp?
Does the math check out?
Why those thermistors, you may ask. Well because they're readily available at the local electronics show in Australia, whereas the shipping price from Mouser or Element14 far outweighs the cost of an appropriately sized thermistor.
@Munce31 NTC thermistors work by getting very hot (eg Heating up to the point where their resistance falls off dramatically, High resistance initially.)
If you put them in parallel you need to ensure the current through each one is high enough they can still heat up.To find that current you need to measure the steady state current of your pump, then size the NTC's to that. It's a long time since I did this but the graphs in the datasheets show you how their resistance will change. Their rating is not the 'inrush' rating, it's the nominal maximum steady-state current they can handle.
Two diodes sounds like overkill, but it will not break anything. And do not 'test' your NTC by touching it, I have a small burn on one of my fingers to remind me of this.
@EasyTarget According to the data sheet of the air pump, the unloaded current is equal to or less than 450mAh, so i'd expect more when loaded.
Unfortunately the details on the thermistor are thin, however it is mentioned in the specifications that the DC current rating is 200mAh. I'm assuming that is maximum.
So if I use three in parallel that would bring total resistance down to 33ohm and total current capacity to 600mAh, which might be close to loaded current draw of the pump.
I guess there's no harm in trying it out I guess.
https://www.jaycar.com.au/100-epoxy-dip-ntc-thermistor/p/RN3432
@Munce31 said in 24V air/vacuum pump questions pertaining to inrush current:
Something that can be tested I guess.
I think so too, so long as there is enough power in the thermistors to heat them up, but not exceed the 500mW max. Most NTC discussions I have ever seen focuss on AC supply, not DC.
That's the spirit! I had a small point, I guess the pump runs continuously? if it is stop/starting make sure there is enough time between cycles for the NTC's to cool down. They are not suitable for bang-bang type controllers.
@EasyTarget said in 24V air/vacuum pump questions pertaining to inrush current:
Yes the pump will be run as part of a berd-air-like system, so mostly will be on and not switched on and off.
Weighing up my options I think the most effective option is to remap a heater to a fan port. I'll investigate this further. Thanks for your help!
Yes, when using a pump having a brushed DC motor, it is better to drive it from a spare heater port if you have one. Don't forget to add the flyback diode.
@dc42 Thanks for confirming that using a spare heater port is a better option for an air pump.
Yes, I will be installing a flyback diode.
However, would it be beneficial if I use two? One screwed in at the heater port terminals to be closer to the mosfet, and another at the motor to reduce any interference created by the PWM?
Also, will the heater port pwm up to 25khz, as recommended in other threads?
